Car cutting out #453491
08/29/09 04:16 PM
08/29/09 04:16 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Have a 70 440 runs and idles fine and drive fine for about 5 to 10 mins once warm it starts cutting out and dies, like losing all spark. I pulled over checked coil for spark good, let set for about 5 min. started back up and drove 3 min home on my street gave a little gas started missing out again.. Any help?
Re: Car cutting out [Re: mc4406] #453492
08/29/09 04:19 PM
08/29/09 04:19 PM
Kirkland, Washington
Pacnorthcuda Offline
one possibility:
Check the ignition power feed at the bulkhead connector. Clean the terminals as best you can and try to restore a little tension to the female connector (carefully). Often this connection is weak.
Re: Car cutting out [Re: Pacnorthcuda] #453493
08/29/09 04:24 PM
08/29/09 04:24 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
which connection? At the ballast. I have the old points distributer in it.
Re: Car cutting out [Re: mc4406] #453494
08/29/09 04:27 PM
08/29/09 04:27 PM
No, the bulkhead connector locate just inboard of the brake mastercylinger and down a bit. By the back of the drivers side engine head. On the firewall. Its a plastic block connection that the engine wiring harness connects to.
You could start by wiggling it while the engine is running to see if it dies---then you KNOW its a problem.
Re: Car cutting out [Re: Pacnorthcuda] #453495
08/29/09 04:32 PM
08/29/09 04:32 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
ok, i'll go check. It's all new wiring so i'll make sure it all tight
Re: Car cutting out [Re: mc4406] #453496
08/29/09 04:39 PM
08/29/09 04:39 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Connection good, wiggled it pretty good will running and nothing, We just finished it up today so it first trip out to get some gas and back home is when it did it, have had it idling for 15+ mins in the garage giving it a shake down, everything seemed fine until on the way back some was going to check kickdown linkage action so i pushed her to the floor and started missing out so i let off then she died.. few min later started and drove back here. Probably should install electronic dist.
Re: Car cutting out [Re: mc4406] #453497
08/29/09 04:53 PM
08/29/09 04:53 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
I just was checking everything over and saw the neg side of the coil arching toward the center?? Bad coil? going to get another one off another vehicle and see if thats it.
Re: Car cutting out [Re: mc4406] #453498
08/29/09 05:02 PM
08/29/09 05:02 PM
sounds like you found the problem.
Re: Car cutting out [Re: Pacnorthcuda] #453499
08/29/09 05:09 PM
08/29/09 05:09 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Is there a diff between electronic ign coil vs points coil? other vehicle has msd blast coil for electronic
Re: Car cutting out [Re: mc4406] #453500
08/29/09 05:15 PM
08/29/09 05:15 PM
you can run a blaster coil with a points system as long as you have a ballast resistor in place. Which it sounds like you do.
Re: Car cutting out [Re: Pacnorthcuda] #453501
08/29/09 06:55 PM
08/29/09 06:55 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
Coil not the prob, replaced and went for another drive and bam did it again, seems to start when it shifts in to drive and you are just getting up to speed. then starts missing bad put it in neutral it smooths out, but put it back in gear and it does it again..
Re: Car cutting out [Re: mc4406] #453502
08/29/09 07:07 PM
08/29/09 07:07 PM
Could it be fuel starvation? Weak fuel pump or low float level?
Will it stumble evey time you try to go uphill with some moderate to heavy throttle???
Re: Car cutting out [Re: Pacnorthcuda] #453503
08/29/09 07:16 PM
08/29/09 07:16 PM
Central, Indiana
mc4406 Offline OP
mc4406  Offline OP
Central, Indiana
New fuel pump and carb off another running vehicle with no problems.I think i'm going to put a electronic set up on tonight and see if that cures it. hopefully new pump is not junk, but it could be..
Re: Car cutting out [Re: mc4406] #453504
08/29/09 08:08 PM
08/29/09 08:08 PM
Andrewh Offline
Andrewh  Offline
sounds like the coil wire then.
If you saw arcing, then the insulation is going or gone.
Might even be your whole set of plug wires.
