polyethylene fuel cell question #453392
08/29/09 02:52 PM
08/29/09 02:52 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
hello,I have a polyethylene fuel cell mounted in the trunk of my car. it is ventilated correctly to the outside and none of the fuel lines have leaks, but I get a strong gas odor in the trunk and passenger compartment. does anyone know if this is common with the poly cells? does poly permiate fumes ? have to replace with aluminum cell to fix problem? Thanks, Tom.
Re: polyethylene fuel cell question [Re: Tom Fox] #453393
08/29/09 03:34 PM
08/29/09 03:34 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Tom .. the problem is .. is these poly tanks are NOT fuel-cells ...as defined by NHRA and NASCAR.
All they are is a simple fuel tank.
The fumes that you have ...would not be present with a proper "fuel cell" that is vented-to-the-outside correctly.
Re: polyethylene fuel cell question [Re: Tom Fox] #453394
08/29/09 05:33 PM
08/29/09 05:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes poly can and will permeate fuel vapors... unless
it has a permeation barrier molded into it(which MOST
of these cheaper cells dont)... but I must say that
I dont smell any vapors from mine.... you might want
to check the filler cap ring to make sure that is
sealed... also the cap. Where does your vent dump at
Re: polyethylene fuel cell question [Re: MR_P_BODY] #453395
08/29/09 10:21 PM
08/29/09 10:21 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I found the seal ring lose on mine snugged everything up and it was fine.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: polyethylene fuel cell question [Re: Tom Fox] #453396
08/29/09 10:21 PM
08/29/09 10:21 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Check the gasket on the cap. My RCI cap gaskets go bad every 6 months or so. I bought 10 gaskets from jegs.
Re: polyethylene fuel cell question [Re: Tom Fox] #453397
08/29/09 11:36 PM
08/29/09 11:36 PM
MNobody Offline
MNobody  Offline
Mine does the same thing when the ambient temp get's warmer. I have mine vented through the trunk floor and vapors rise up i guess. Never noticed any bad seal's
