Front Leaf Spring Hangers
#453324
08/29/09 12:48 PM
08/29/09 12:48 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
Looking at lowering the Dart. I heard alot about Flipping the Front Hangers so yesterday afternoon I decided to do that.
What was never discussed with this flipping of the front hangers, is that it can be done if your willing to redrill the mounting holes since the hangers are "Keyed" so that they will only go on 1 way.
The Top 2 studs are centered at 1.5" and the bottem 2 studs are centered at 1.825".
So now the questions to those who have done this.
If you redrilled did you use a backing plate to reinforce the mount?
How about if you were to weld some .1875 to extend the flange and redrill? Could you trust the welds?
I know that Mancini and Firm Feel both sell this hangers with the second hold drilled.
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
Re: Front Leaf Spring Hangers
[Re: AndyF]
#453329
08/29/09 02:21 PM
08/29/09 02:21 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
Why hack up the holes when the dropped hangers are available?
"hack up" is not the wording I'd use. Modify would be accurate. You modify lots of stuff Andy
Why modify if dropped hangers are available? Maybe because its around $100 saved and serves the same purpose Why spend money if you dont have to?
[Re: Lefty]
#453331
09/05/09 05:54 PM
09/05/09 05:54 PM
Noblewk
Southern Cal
Well here is the result for dropping the SS Springs using the AREngineering Front hangers and a 1" lowering block. The Picture on the Left top is where I started, Left Bottem is with the AREngineering Hangers and Top right is with the front hangers and a 1" lowering block.
2000 Ram
2005 Durango Hemi.
