65 dodge coronets directionals way too fast #453233
08/29/09 10:55 AM
08/29/09 10:55 AM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
why are both left and right directionals going real fast when i turn them on, directionals work but way too fast, any help?
Re: 65 dodge coronets directionals way too fast [Re: JACKSON] #453234
08/29/09 11:20 AM
08/29/09 11:20 AM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
Probably in the signal stat(relay)Any parts house should have them! I buy alot of parts from my local Dodge dealership!
Re: 65 dodge coronets directionals way too fast [Re: JACKSON] #453235
08/29/09 11:23 AM
08/29/09 11:23 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Start with the easy stuff, try a new flasher unit. They work by the heating effects of electricity on a bimetallic strip; as it heats it causes the strip to bend and break the circuit, then as it cools it returns to original and makes the circuit to start the cycle over again. It's not too unusual for things like that to break down and change their characteristics, plus if you've put different lamps in or have a little corrosion, etc. it will change the current flow and alter the properties from design. An added lamp or two, say like trailer lamps will cause the same effect. At any rate, start with the 2 - 3 dollar part first, if that doesn't fix it it's time to look at the current draw of the circuit and/or the voltage supplied.
Mike
Re: 65 dodge coronets directionals way too fast [Re: 1E2C] #453236
08/29/09 12:28 PM
08/29/09 12:28 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Not sure if yours is the same but my 67 coronet had the original square flashers.. I purchased some NOS and they worked about the same.. I replaced both of my flashers with modern round ones and they work great..
I have been told replacing the original bulbs ( can't remember the number) with newer 1157 bulbs will draw more current??
Re: 65 dodge coronets directionals way too fast [Re: minivan] #453237
08/29/09 01:18 PM
08/29/09 01:18 PM
And now for the correct answer. Round or square, flashers are a crap shoot and they CAN CHANGE WITH AGE.
(Just imagine how worn out YOU would be if you had to sit there and flash lights all those years)
Anyway, round or square matters not. Just get a heavy duty flasher and be done with it. Easy.
Re: 65 dodge coronets directionals way too fast #453238
08/29/09 01:40 PM
08/29/09 01:40 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I remember back in the day we would put in the Heavy Duty flashers when we pulled a trailer for the extra load on the unit. When the trailer was disconnected from the vehicle the turn indicators would flash faster because the extra bulbs were no longer attached to the overall system. Just my
Re: 65 dodge coronets directionals way too fast [Re: maximus] #453239
08/29/09 03:50 PM
08/29/09 03:50 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Get one of the new electronic one.Have them in my 65 and ny 58 Harley.Both didnt want to flash right.After I installed the electronic ones they are perfect.They are only a few bucks more than the old style.Rocky
Chrysler Firepower
Re: 65 dodge coronets directionals way too fast [Re: maximus] #453240
08/30/09 08:48 AM
08/30/09 08:48 AM
Blanchard, OK
Real-Fury Offline
Real-Fury  Offline
Blanchard, OK
Certainly worth checking out!
Butch
Re: 65 dodge coronets directionals way too fast [Re: Real-Fury] #453241
08/30/09 11:31 AM
08/30/09 11:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Butch
Actually thats backwards as when you unhook a trailer with extra lites on it the turn signals will slow down. The reason for a heavy duty flasher with a trailer is because with the extral lites the flasher heats faster and the lites blink faster. The heavy duty flasher takes longer to heat the bi-metal in the flasher so it flashes slower. When you take the extra trailer lites away it will flash slower. Just like when a bulb blows out on one side and then that side slows down on the older cars like our muscle cars. Newer cars are different. Ron
Re: 65 dodge coronets directionals way too fast [Re: 383man] #453242
08/30/09 02:35 PM
08/30/09 02:35 PM
Andrewh Offline
Andrewh  Offline
um actually I think you have that backwards.
When a bulb goes out on my car a 65 coronet, it blinks faster on that side.
Re: 65 dodge coronets directionals way too fast [Re: Andrewh] #453243
08/30/09 02:56 PM
08/30/09 02:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
HD flasher takes more resistence to flash. Fewer bulbs mean slower flash. Andrewh, that may be caused if the broken filament shorts to the other filament or the bsae.
