procedure to lower back on ladder bar car #453224
08/29/09 10:43 AM
08/29/09 10:43 AM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
i wanna drop the back of my car 1".
looks like i can lower the rear coilover shock mount down with plenty of adjustability, whats the best way to hold the car up so i dont drop the rear down hard, i want to be able to lower it slowly, to put the shocks in a little lower on the mount. dont want the back of the car to come crashing down.
any help?
Re: procedure to lower back on ladder bar car [Re: JACKSON] #453225
08/29/09 10:48 AM
08/29/09 10:48 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I would think you would place the car on jack stands and use a floor jack under the rear end to adjust it to the location you want .
Re: procedure to lower back on ladder bar car [Re: rowin4] #453226
08/29/09 11:00 AM
08/29/09 11:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... thats all I would do
EDIT
re adjust the pinion angle also
Re: procedure to lower back on ladder bar car [Re: MR_P_BODY] #453227
08/29/09 12:39 PM
08/29/09 12:39 PM
EDIT
That is the way I do it, let the floor jack down so it is barely holding the rear end up to have a tiny bit of weight on the shocks, remove the bolts and either raise or lower the jack to the holes you want to us
Re: procedure to lower back on ladder bar car [Re: Cab_Burge] #453228
08/29/09 04:03 PM
08/29/09 04:03 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
do you think the pinion angle will change enough for a readjustment?
going down 2 holes only.
Re: procedure to lower back on ladder bar car [Re: JACKSON] #453229
08/29/09 04:23 PM
08/29/09 04:23 PM
gregsdart Offline
gregsdart  Offline
yes
Re: procedure to lower back on ladder bar car [Re: JACKSON] #453230
08/29/09 05:28 PM
08/29/09 05:28 PM
You should check it now and after switching hieghts, it is always better to be safe than sorry
