reusing fel pros? #453196
08/29/09 09:33 AM
08/29/09 09:33 AM
KY
juicedcuda Offline OP
KY
I put my heads on about two weeks ago and still haven't started the motor. Now for other reasons, I need to pull the heads back off. Would it be ok to reuse my fel-pro 1009 head gaskets since they haven't been run yet?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: reusing fel pros? [Re: juicedcuda] #453197
08/29/09 09:57 AM
08/29/09 09:57 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
if it hadnt been run, i'd do it. in fact, i thinki have done it. its the heat that I'd be worried aboiut. since you didnt start it, it should be ok.
Re: reusing fel pros? [Re: aarcuda] #453198
08/29/09 09:58 AM
08/29/09 09:58 AM
, PA
sleepyhead416 Offline
, PA
I've done it also.
Re: reusing fel pros? [Re: aarcuda] #453199
08/29/09 10:06 AM
08/29/09 10:06 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Gaskets are made to seal with the metal rings around the cylinders and water jacket holes. When compressed they are flatted out. Reusing that type of gasket imo would be a 50/50 deal with one of those 50's causing damage to your motor.
Re: reusing fel pros? [Re: sleepyhead416] #453200
08/29/09 10:08 AM
08/29/09 10:08 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've done it many times. Had one head with screwed up alternator hole would always seem to put it on the pass side the notice after the heads were torqued? off they came and back on again. never a problem.
Re: reusing fel pros? [Re: juicedcuda] #453201
08/29/09 12:47 PM
08/29/09 12:47 PM
I have reused them after dyno testing and had no problems, retorque them like you torque them the first time
Re: reusing fel pros? [Re: juicedcuda] #453202
08/29/09 01:59 PM
08/29/09 01:59 PM
gregsdart Offline
gregsdart  Offline
Mark them for the side they came off, so they go on exactly like they did the first time and all is well, for a motor not fired yet.
Re: reusing fel pros? [Re: juicedcuda] #453203
08/30/09 06:48 PM
08/30/09 06:48 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I have the worst answer possible!
My buddy was "budget racing" many years ago. He had a big block Satellite and he would blow the engines to pieces when he missed a shift.
(DON'T ask)
I would then supply him big block short blocks by the dozen to keep him up and running.
(That's the "budget" part... )
He re-used the same Felpro head gaskets AND the same Felpro intake gasket over a dozen times, different short block every time.
Sad pathetic story, but true!
CrAzYMoPaRGuY
