block sealer #453166
08/29/09 09:06 AM
08/29/09 09:06 AM
Iowa
coronetville Offline OP
Iowa
when somebody clearenced my block for a stroker crank, they hit into the water jacket, now has a slight leak. Whats the best block sealer out there?
Re: block sealer [Re: coronetville] #453167
08/29/09 09:45 AM
08/29/09 09:45 AM
south louisiana
lowell66dart Offline
south louisiana
If it's still apart you can either weld or use that good epoxy they use on heads. I think you can get it from Shady Dell or Reher Morrision. If you want something to dump in the radiator I have had good luck with Barr's. Get the silver stuff that looks like glitter.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: block sealer [Re: coronetville] #453168
08/29/09 11:53 AM
08/29/09 11:53 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Irontite ceramic but cannot be used with antifreeze
irontite has some other ones for antifreeze!
http://irontite.com/store/index.php?main_page=product_info&cPath=1&products_id=1
looks like after you run it then leave it sit with this you can add coolent with another sealer suggested???
Re: block sealer [Re: coronetville] #453169
08/29/09 12:48 PM
08/29/09 12:48 PM
Try and find some K&W block sealer
Post deleted by Defbob [Re: Cab_Burge] #453170
08/29/09 02:12 PM
08/29/09 02:12 PM
Re: block sealer #453171
08/29/09 04:08 PM
08/29/09 04:08 PM
Iowa
Iowa
I have a little water in no. 7 cyl. the engine rebuilder said whoever built it, got into the water jacket when they were grinding crank clearance. they had block hardener on it but I still have a small leak
Post deleted by Defbob [Re: coronetville] #453172
08/29/09 04:41 PM
08/29/09 04:41 PM
Re: block sealer #453173
08/29/09 05:11 PM
08/29/09 05:11 PM
Iowa
Iowa
ther is no antifreeze but there is wet vetter
Re: block sealer [Re: coronetville] #453174
08/29/09 08:38 PM
08/29/09 08:38 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We used the blue devil sealer (about $50/bottle). I've heard the Moroso cermanic seal works good too and it's cheaper.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
