performance gains ,square jetting?? #453016
08/29/09 02:26 AM
08/29/09 02:26 AM
canada,NB
jb15 Offline OP
jb15  Offline OP
canada,NB
Hey Guys: wondering if it's worth trying square jetting over useing P.V in front ? have 3 to 3.5 inchs of vacume at idle and am thinking maybe the P.V is closing or partially,has any one seen gains by square jetting,would like to try it in the morning... Jim,
ran a 9.197 at 143.5 mph with 1.260 60fts yesterday....
Re: performance gains ,square jetting?? [Re: jb15] #453017
08/29/09 02:40 AM
08/29/09 02:40 AM
Glendale AZ
Comp Chassis 2 Offline
Glendale AZ
In a combo as fast as yours, with that low vacume. I would delete the power valve . May not be faster ,but I bet it repeats better
Re: performance gains ,square jetting?? [Re: Comp Chassis 2] #453018
08/29/09 02:47 AM
08/29/09 02:47 AM
canada,NB
jb15 Offline OP
jb15  Offline OP
canada,NB
thanks for the input, I'll try it tomorrow and post the results... Jim
Re: performance gains ,square jetting?? [Re: Comp Chassis 2] #453019
08/29/09 10:04 AM
08/29/09 10:04 AM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
I agree 100% and in your case the pv would only be confused by the "altitude changes"
Re: performance gains ,square jetting?? [Re: JUST_N_TIME] #453020
08/29/09 11:39 AM
08/29/09 11:39 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Taking the pvs out of the equation just makes it simpler to deal with
Re: performance gains ,square jetting?? [Re: emarine01] #453021
08/29/09 02:08 PM
08/29/09 02:08 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
emarine, how did your square jetting turn out as far as performance?
Yeah, it's got a smallblock.
Re: performance gains ,square jetting?? [Re: 340B5] #453022
08/29/09 02:20 PM
08/29/09 02:20 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I had to play with it a little, @ first I created a slight bog on flashing the converter, I increased the squirter size of the rear 4# and sorted it out, In all I am running less fuel thru the engine and making better power, its a bg annular carb so they are a little different than holley's to figure out @ this point I like the square jetting better, in a race only car Its just easier to figure out
Re: performance gains ,square jetting??(update) [Re: emarine01] #453023
08/30/09 06:25 AM
08/30/09 06:25 AM
canada,NB
jb15 Offline OP
jb15  Offline OP
canada,NB
Air not as good as sat. but the only diff, with my car was a little noisey cleaning out the plugs during burnout.pulled the same on the run. a mopar pitted beside me with similer combo made no changes from previous day slowed 10th1/2 sec. so looks like a possible gain as well... Jim
