Cam Dynamics 7000 Plus cam help #452968
08/29/09 12:23 AM
08/29/09 12:23 AM
Eastern WA
P
ProStock1320 Offline OP
P
Eastern WA
This one is for you "back in the day" old DC catalog kinda guys.
So I'm looking at a DC cam chart and see P4007277 listed as a Cam Dynamics Stock "Cheater" cam with .467/.483 lift but duration is 352/380 ??? If memory serves, there are only 360 degrees in a circle, right? What am I missing? Someone please enlighten me! Thanks.
Re: Cam Dynamics 7000 Plus cam help [Re: ProStock1320] #452969
08/29/09 12:40 AM
08/29/09 12:40 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Remember the cam turns at half crank speed.
The only reason for these cams is to meet stock lift specs while cramming in the maximum possible duration. They have almost square lobes that just slam the valves open and closed so are very hard on valvetrain parts...
A few years ago, one of the car mags (think it was Hot Rod but not sure) had one lying around and wanted to try it... wish I'd saved the article. Anyway they said it would not idle under 1800 rpm and made basically no vacuum, because both valves are open most of the time, but it would rev really high.
Re: Cam Dynamics 7000 Plus cam help [Re: DrCharles] #452970
08/29/09 01:15 AM
08/29/09 01:15 AM
Eastern WA
P
P
Eastern WA
So do you half the duration number to obtain modern cam duration numbers or is there another method?
Re: Cam Dynamics 7000 Plus cam help [Re: ProStock1320] #452971
08/29/09 10:26 AM
08/29/09 10:26 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Friend used to use those cams on a tractor puller back in the day and those 440's would pull to 7500 at least.
I remember trying to get my head around how there could be more degrees than in a circle!! but alas cam deg are in crank deg and cam is turning 1/2 speed so 380 deg on the crank is 190 on cam circle.
But it in a block and map it out with your degree kit
Re: Cam Dynamics 7000 Plus cam help [Re: Dodgem] #452972
08/29/09 10:56 PM
08/29/09 10:56 PM
Eastern WA
P
P
Eastern WA
I know a stock eliminator guy down in northern Calif that says this cam makes gobs of power. I'm trying to figure out how 190* of duration can do that and what this thing equates to in modern cam terms. Is there a tech bulletin or white paper on it somewhere? I do see Dr C's note about an article Hot Rod(?) may have run. Anyone got another source? I'm thinking about sticking one in the boy's 383 AMC Hornet.
Re: Cam Dynamics 7000 Plus cam help [Re: ProStock1320] #452973
08/29/09 11:52 PM
08/29/09 11:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My old engine book and DC books that listed that cam are gone. now everyone tells me no such cams existed!!! LOL!!
I'll bet they were 305/320 duration @ .050 at least.
Be fun to try one!!
Re: Cam Dynamics 7000 Plus cam help [Re: Dodgem] #452974
08/29/09 11:54 PM
08/29/09 11:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Cam Dynamics 7000 Plus cam help [Re: ProStock1320] #452975
08/29/09 11:55 PM
08/29/09 11:55 PM
Boise
Moparteacher Offline
Boise
Chrysler used to measure duration at .006" lift, and if you go back far enough they measured the the intire lobe from start of the ramp to ramp. That's where you get the large numbers.
A common duration figure, @.050" lift, for a stock eliminator cam starts at about 260 degrees.
These cams are extremely peaky; they work in a very narrow rpm band.
Re: Cam Dynamics 7000 Plus cam help [Re: Moparteacher] #452976
08/30/09 12:00 AM
08/30/09 12:00 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
The .006" spec is an SAE spec, usually called the "advertised duration". I have one for a 340 that's never been used. I never measured it but the lobe has a flat nose on it. It looks like the lobes are designed to cause the valvetrain to fly off the end getting more lift and land on the other side of the ramp.
Floyd Lippencott IV
Re: Cam Dynamics 7000 Plus cam help [Re: ProStock1320] #452977
08/30/09 07:28 AM
08/30/09 07:28 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Be advised that you can not just stick a stocker cam in. They are very large at all lifts and have big dwell numbers so they eat up piston to valve like crazy. My old 360 stocker with the piston in the hole .051 and the valves sunk had little P to V.
Also because the acceleration/decell ramps are so steep they require a ton of spring for a hydraulic lifter. To really take advantage of a cam like that ceramic lifters are a must. I like to have seat pressures of around 220 and 420+ over the nose. My 340 stocker goes through a set of springs about every 30 runs or so.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Cam Dynamics 7000 Plus cam help [Re: sixpackbee] #452978
08/30/09 05:21 PM
08/30/09 05:21 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I ran this cam in a 440 six pack back in the early 80's ,stock cast pistons, stock 906 heads, ran Direct Connection springs,retainers, 1.86 installed height, 100 lbs closed and 300 lbs open with stock rockers which were more like 1.42 which kept it closer to legal lift. Ran it 2 seasons, ran 11.80's 3600 lb Super Bee, Stuck it in a tubbed out 3000 lb. Duster,same trans and converter, only TM7 and 750 Holley and went 11.00 in good air,11.30's in the heat, bracket raced it for a couple years. Great Cam. Piston to valve clearance is critical. I know a couple guys who unintentually put their own valve reliefs in their pistons
Re: Cam Dynamics 7000 Plus cam help [Re: Lil Wedge] #452979
08/31/09 01:28 AM
08/31/09 01:28 AM
Eastern WA
P
P
Eastern WA
Sounds like some of that old 'Mopar black magic' that used to get whispered about. Thanks for all the good info. I most certainly will watch the piston/valve issue and the spring thing. Anybody want to venture a guess on rpm band or convertor choice?
