Short Fills for the StReet #452526
08/28/09 02:06 PM
08/28/09 02:06 PM
U.S.
moparniac Offline OP
U.S.
I know some of you guys fill up to the freeze plugs... Is there any over heating issues going with a fill on the street or any other issues. thx
Mopar Performance
Re: Short Fills for the StReet [Re: moparniac] #452527
08/28/09 03:04 PM
08/28/09 03:04 PM
organ
maximum entropy Offline
organ
i've never done it, but from what i've gathered from my pals here on moparts, oil temperature will be the issue. sounds like if you run a good engine oil cooler it should be ok?
Re: Short Fills for the StReet [Re: moparniac] #452528
08/28/09 03:21 PM
08/28/09 03:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
if your starting from scratch why not get a race block and be done with it? it will save you money in the long run.
Re: Short Fills for the StReet [Re: Quicktree] #452529
08/28/09 04:21 PM
08/28/09 04:21 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Great Advise
Re: Short Fills for the StReet [Re: Quicktree] #452530
08/28/09 04:24 PM
08/28/09 04:24 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
No need in trying to make real power with a stock block , figure out how much hp you are really after and ask how well it will hold up
Re: Short Fills for the StReet [Re: cudabunch] #452531
08/28/09 04:57 PM
08/28/09 04:57 PM
organ
organ
like i said, from what i've gathered from my pals here on moparts, it's better to go with an aftermarket block.
Re: Short Fills for the StReet [Re: maximum entropy] #452532
08/28/09 05:18 PM
08/28/09 05:18 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i have a 1970 360 block filled to the top of the soft plugs. 408 stroker set up street/strip and engine runs 180* cruising and 200* in town with a 160* stat in 80* weather. no oil cooler or oil temp gauge, but no issues yet. second season on this set up. i use brad penn oil.
Re: Short Fills for the StReet [Re: maximum entropy] #452533
08/28/09 05:34 PM
08/28/09 05:34 PM
U.S.
U.S.
OKAY
Mopar Performance
Re: Short Fills for the StReet [Re: moparniac] #452534
08/28/09 06:03 PM
08/28/09 06:03 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Problem is that not everyone has the cash up front to lay down on a new block.. Cast is 2500 and up and the alum. are 4100 and up.. I've run a short fill on the street for a couple of years.. never had a problem with it. If you got a block why not use it and run the car, instead of waiting another 5 years of saving money to drive it.. I say live in the now. Save money and buy a block at a later date...
Re: Short Fills for the StReet [Re: 70dusterjohn] #452535
08/28/09 10:41 PM
08/28/09 10:41 PM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
I havea 71 casting '230 block low deck with a fill to the top of the freeze plugs, Gauge reads 175-180 (stays in the middle) and it's fine while cruising.
The issue isn't the coolant it's the Oil, once it gets hot in traffic it wants to stay hot and it takes an awful lot of part throttle cruising to bring the oil temp back down which (if you think about it) does put a strain on the cooling system. she starts getting hot on you in traffic it's really a China Syndrome scenario, a cooler is cheap insurance cause you never know when you might be in a situation where you can't get to an open freeway.
WIZE
In Car:
Re: Short Fills for the StReet [Re: 70dusterjohn] #452536
08/30/09 12:34 PM
08/30/09 12:34 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Wedgie has the cash he just does a LOT of research
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Short Fills for the StReet [Re: 67HEMI] #452537
08/30/09 12:54 PM
08/30/09 12:54 PM
U.S.
U.S.
I bought a race block.... tired of threads on which block to buy
Mopar Performance
Re: Short Fills for the StReet [Re: moparniac] #452538
08/30/09 01:02 PM
08/30/09 01:02 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Good move Wedgie, a stock block was my biggest mistake on my last build, Had I found this site sooner I would have saved a lot of time
Re: Short Fills for the StReet [Re: 67HEMI] #452539
08/30/09 01:49 PM
08/30/09 01:49 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
we all do
Re: Short Fills for the StReet [Re: moparniac] #452540
08/30/09 05:21 PM
08/30/09 05:21 PM
that will be on of the best decision you can make on a high output Mopar No sense in risking your life over a few dollars instead waiting a little longer to acrue the cash for the better block
Re: Short Fills for the StReet [Re: Streetwize] #452541
08/31/09 01:26 PM
08/31/09 01:26 PM
organ
organ
like i said, from what i've gathered from my pals here on moparts, oil temperature will be the issue. maybe a good engine oil cooler is in order?
