4 speed A833 question #451809
08/27/09 02:11 PM
08/27/09 02:11 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
HI,
Is there someone there know the easy way to change the
mainshaft yoke bushing on extension housing ( 4 speed A833 transmision)?
Re: 4 speed A833 question [Re: AAR70] #451810
08/27/09 02:38 PM
08/27/09 02:38 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Is it installed on the transmission or off ?
Re: 4 speed A833 question [Re: JohnRR] #451811
08/27/09 03:10 PM
08/27/09 03:10 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
The extension housing is installed on the transmision
Re: 4 speed A833 question [Re: AAR70] #451812
08/27/09 03:12 PM
08/27/09 03:12 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
There is a puller designed for the job , but you might have trouble finding it in your country .
Re: 4 speed A833 question [Re: JohnRR] #451813
08/27/09 03:18 PM
08/27/09 03:18 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Do you know where in USA I can buy that puller?
Re: 4 speed A833 question [Re: AAR70] #451814
08/27/09 04:21 PM
08/27/09 04:21 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Re: 4 speed A833 question [Re: AAR70] #451815
08/27/09 06:28 PM
08/27/09 06:28 PM
ohio
B5 GTX Offline
B5 GTX  Offline
ohio
I would check with brewers performance, if they do not have it I'm sure they can point you in the right direction.
http://www.brewersperformance.com/
good luck
scott
Re: 4 speed A833 question [Re: AAR70] #451816
08/28/09 08:18 AM
08/28/09 08:18 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Here are the tools , price has gone up about 50% since I bought them about 7or 8 years ago .
puller http://millerspecialtools.spx.com/Detail.aspx?id=255
installer http://millerspecialtools.spx.com/Detail.aspx?id=250
Re: 4 speed A833 question [Re: JohnRR] #451817
08/31/09 03:56 AM
08/31/09 03:56 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Thank you
