Re: building a 383.. is 440 source the place to go?
[Re: coronet1966d]
#451473
08/27/09 04:12 PM
08/27/09 04:12 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
well i found a 383/727 out of a 67 new yorker for $300 and the same combo out of a 68 satellite for $350. ive only seen a handfull of 440's locally and they go for at least double and im not a big fan of the 400
i didnt realise the 383 wasnt a good motor to build? i looked up a 67 383 and it listed it as 280hp/400 ftlb 10:1 CR i figured heads cam intake and headers would easily get that in the 400hp neighborhood
maybe ill just hold out for a deal on a 440
If you found a 67 New Yorker,it had a 440 unless someone changed it.
[Re: 1_WILD_RT]
#451475
08/27/09 04:35 PM
08/27/09 04:35 PM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
thanks for the responses guys.. but to clear a few things up 1)i dont have an engine yet so 383vs400vs440 comments are welcome! 2)just because im putting it into a truck doesnt mean im towing 3)this is my hot rod and im shooting for high 12's as it sits right now with an unported iron headed 360 it knocked down a 13.8
[Re: coronet1966d]
#451477
08/27/09 04:44 PM
08/27/09 04:44 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Something to note going from a 360 to 383... You are adding about 80lbs depending on the components. The 360 is a 3.58 stroke and 4.00 bore. The 383 is a 3.37 stroke and 4.25 bore. IMO, you are making a lateral move at best... With that truck's mass, you want as much stroke as you can get. If it were me, I'd invest in gears or parts for the 360 to go faster, or get your hands on a 440 and brake booster so you can bolt it in.
