Re: 4.250 stroke in a SB? [Re: SB449VALIANT] #451271
08/27/09 09:55 PM
08/27/09 09:55 PM
It's basically just a round skirt piston at 1.31" CH, small dome, .043 ring pack, Vertical gas ports and a .990 pin, setup for GRP 1200 underneath, (piston with ligting progrm @ 450grm
nice looking piston . who made them?
Re: 4.250 stroke in a SB? #451272
08/28/09 02:33 AM
08/28/09 02:33 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Those are Ryan/Diamond's custom pistons' crank is yours....lol
Re: 4.250 stroke in a SB? [Re: AndyF] #451273
08/28/09 08:01 AM
08/28/09 08:01 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Callies said that to get the 4.250 to balance they would need 2 or 3 pieces of heavy metal on each end.
Yes, my balance job was quite expensive. It took 6 pcs to get it to internally balance.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 4.250 stroke in a SB? [Re: S/ST 3040] #451274
01/15/10 06:16 PM
01/15/10 06:16 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
CompStar 6.250" .927" x 2.100"
same rods i use except 6.300 nice pieces , with 4 inch crank.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 4.250 stroke in a SB? [Re: B3422W5] #451275
01/15/10 06:26 PM
01/15/10 06:26 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
good info,thanks
Re: 4.250 stroke in a SB? [Re: B3422W5] #451276
01/15/10 06:48 PM
01/15/10 06:48 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Those Compstars are in the EM 394" engine now with 3.79" billet crank.
Re: 4.250 stroke in a SB? [Re: S/ST 3040] #451277
01/15/10 07:03 PM
01/15/10 07:03 PM
S/ST 3040 Offline
S/ST 3040  Offline
Re: 4.250 stroke in a SB? [Re: S/ST 3040] #451278
01/15/10 07:04 PM
01/15/10 07:04 PM
Mcallen, TX
Mcallen, TX
Re: 4.250 stroke in a SB? [Re: S/ST 3040] #451279
01/15/10 07:32 PM
01/15/10 07:32 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Vic, What was the rod length?
Re: 4.250 stroke in a SB? [Re: emarine01] #451280
01/15/10 07:34 PM
01/15/10 07:34 PM
S/ST 3040 Offline
S/ST 3040  Offline
It's still 6.250".
Re: 4.250 stroke in a SB? [Re: S/ST 3040] #451281
01/15/10 07:43 PM
01/15/10 07:43 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Re: 4.250 stroke in a SB? [Re: emarine01] #451282
01/16/10 11:29 AM
01/16/10 11:29 AM
Mid-Ohio
Bakaruda432 Offline
mopar addict
Bakaruda432  Offline
mopar addict
Mid-Ohio
440+ CID SB is there a head for that?
Re: 4.250 stroke in a SB? [Re: Bakaruda432] #451283
01/16/10 01:02 PM
01/16/10 01:02 PM
Mcallen, TX
Mcallen, TX
here is one, indy 360-1 raised port
Re: 4.250 stroke in a SB? [Re: SB449VALIANT] #451284
01/16/10 01:05 PM
01/16/10 01:05 PM
Mcallen, TX
Mcallen, TX
x
Re: 4.250 stroke in a SB? [Re: SB449VALIANT] #451285
01/16/10 01:07 PM
01/16/10 01:07 PM
Mcallen, TX
Mcallen, TX
xx
Re: 4.250 stroke in a SB? [Re: Bakaruda432] #451286
01/16/10 01:54 PM
01/16/10 01:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Weather there is a head for that or not depends on how many RPM you want to turn
Re: 4.250 stroke in a SB? [Re: HotRodDave] #451287
01/16/10 10:33 PM
01/16/10 10:33 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Re: 4.250 stroke in a SB? [Re: AndyF] #451288
01/17/10 01:06 AM
01/17/10 01:06 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Dragrcr is holding back on you guys. He is in the process of installing a 4.500 stroke crank in his new R3 block to build a 501" small block. His crankshaft is a work of art.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: 4.250 stroke in a SB? [Re: PUNK] #451289
01/17/10 05:20 AM
01/17/10 05:20 AM
IL
knyech1 Offline
knyech1  Offline
IL
Wow I would love to see a lot of that when it's done!!
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
