yes a much better gasket
you can get them at the dealer for about 12-15 bones
do not over tighten them,they do not crush,it will strip bolts holes if over torqued.
the bolts are a tad short but work ok,if it strips the hole,usally a longer bolt will work in that hole.
the shorter bolt only goes 1/2 way in the hole...mark that one if it does for later referance.
the new gasket has a o-ring type seal to it,just make sure the pan rail is flat..
I allways tap the from the gasket side to make sure the are not dimpeled from the old style gaskets and over torqueing them
its reusable also,I have had mine of 5-6 times since I bout it a couple yrs ago,even swaped it to the replacement tranny in feb
$ well spent IMO
