Fuseable Link Fuse Blows in drive an reverse?!!! HELP #450833
08/26/09 02:08 PM
08/26/09 02:08 PM
NY
MoparGary7272 Offline OP
NY
I have a 72 /6 gold duster that i just bought off this guy whos kid hacked a lot of stuff up like the radio is cut out and a sound system was spliced in!!, but on the outside wiring harness where the wire from the battery goes into the firewall, he put in an aftermarket fuseable link.. when the car warms up and i put it in reverse the 30amp fuse blows giving me no power anywhere!!!!! now it just started doing it in drive too. when i slow down to stop, the car sound like its going to stall.. the idle is a little high, but low idle fluctuates and if it does stall.. the fuse blows !!.. WHY DOES THE FUSE KEEP BLOWING?!?!
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MoparGary7272] #450834
08/26/09 02:26 PM
08/26/09 02:26 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
linkage coming incontact and grounding out?.Does battery go dead when car just sits
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: WINGCARS_6970] #450835
08/26/09 02:31 PM
08/26/09 02:31 PM
NY
NY
it sat all last night and battery was still good wneh i put a new fuse in it.. but they keep blowing.. out.. im about to just put a wire where the link is haha
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MoparGary7272] #450836
08/26/09 03:30 PM
08/26/09 03:30 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I hope from the "haha" part of that you aren't serious. Doing so would be a REALLY BAD idea. Fuses and fusible links blow for a reason, not because they are "defective" themselves.
I'd start by looking for a serious dead short somewhere. Shifting into drive involves shifting through reverse. There is juice for the backup lights going through the neutral safety switch, so that's a possible point of failure. Disconnect the harness to the NSS and see if anything changes. Do so after starting the car (but before shifting out of park), or begin with it disconnected and duplicate the function of the NSS (ground the appropriate terminal on the starting relay).
Down to just a blue car now.
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HE [Re: MoparGary7272] #450837
08/26/09 04:37 PM
08/26/09 04:37 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Keep the fuse in the circuit, buy a box of fuses and start disconnecting the hacked wiring until the problem goes away. I would start looking for a new under dash harness on eBay or www.wildcatmopars.com. Same thing for the engine harness if it's hacked. Another option is a universal after market harness.
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HE [Re: Lefty] #450838
08/26/09 05:04 PM
08/26/09 05:04 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Get rid of those cheap fuses that keep blowing, splice in a heavy guage wire and buy yourself a fire extinguisher.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HE [Re: badblack68] #450839
08/26/09 06:31 PM
08/26/09 06:31 PM
TX , NJ , FL
W
W
TX , NJ , FL
Is it a column car where maybe battery cable.Is contacting linkage underhood
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HE [Re: WINGCARS_6970] #450840
08/26/09 06:34 PM
08/26/09 06:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need a fusible link not a fuse in the main circuit. Fusible links are slow blow for a reason. Fuses blow fast when spiked.
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HE [Re: badblack68] #450841
08/26/09 07:46 PM
08/26/09 07:46 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: 68HemiB] #450842
08/27/09 11:57 AM
08/27/09 11:57 AM
NY
NY
yea i wouldnt just put a cable between it..not good.. but heres a new update, Reverse lights do not come on!! and bulbs are new... i put a manual choke on and before i shift i open it a little to drop the idle and it shifts into reverse or drive with no fuses blown.. but if the idle is any higher bam.. it blows!! the wiring everywhere else looks fine and the only bad is whats on the outside of the firewall ill have pics soon i'm going over to my buddys mopar yard and cutting out the correct wire on the scamp.. now why is there nothing going to the bulbs
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MoparGary7272] #450843
08/27/09 12:02 PM
08/27/09 12:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked the neutral saftey swith wiring to see if it's shorted? The two outside wires on the plug are in and out for power to the backup lights in reverse.
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MoparGary7272] #450844
08/27/09 12:15 PM
08/27/09 12:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your dealng with 40 year old wiring, that's been hacked on over the years,....why bother!,....just replace everything with new harnesses available from Year One/M&H wiring,.....peace of mine,trouble free from nightmare wiring gremlins
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HE [Re: DAYCLONA] #450845
08/27/09 12:19 PM
08/27/09 12:19 PM
California
mickm Offline
mickm  Offline
California
i agree. if you a) don't have the cash for the new harnesses, or b) want the experience of troubleshooting wiring, then go for it.
otherwise you may well save yourself hours if not days of time and frustration.
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: stumpy] #450846
08/27/09 12:31 PM
08/27/09 12:31 PM
NY
NY
heres a stupid question... wheres the Neutral Safety Switch.. and a new harness is being ordered but im trying to get it running before the weekend.. i also have a new dash thats going in too but wanted the new harness put in when i get the other one out
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MoparGary7272] #450847
08/27/09 12:39 PM
08/27/09 12:39 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
The NSS is down on the driver's side of the transmission, with a three-wire harness connected to it.
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MoparGary7272] #450848
08/27/09 12:41 PM
08/27/09 12:41 PM
TX , NJ , FL
W
W
TX , NJ , FL
The neutral safety switch is threaded into the left side of the transmission case .Has a rubber boot with a 3 pin connector
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: 68HemiB] #450849
08/27/09 10:20 PM
08/27/09 10:20 PM
NY
NY
I looked even closer at the front hack job, and noticed that he had the after market fuse link thing actually spliced onto the fusible link
!!! so i took the fusible link off the scamp and put it on... no lost power but when it goes in drive or reverse it almost stalls or stalls. air fuel mixture?! and reverse lights still dont work BUT when it stalls i have to put it in nuetral to start it.... NSS must be bad!! thanks for all your help!.. elctrical is not my thing, but easier than i thought... so simple but its hair pullin when the littlest thing goes wrong especially when a 15 year old HAD to put a sound system in it!! heres what it looked like...
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MoparGary7272] #450850
08/27/09 10:33 PM
08/27/09 10:33 PM
MNobody Offline
MNobody  Offline
Did he put in a fusible link or just wire in a 30 amp fuse socket?
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MoparGary7272] #450851
08/27/09 10:39 PM
08/27/09 10:39 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
No, that's how it's supposed to work! Only starts in park or neutral.
Does the motor shift a lot in reverse? Is the carb loose?
Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP [Re: MNobody] #450852
08/28/09 03:18 AM
08/28/09 03:18 AM
NY
NY
theres a fusible link AND a 30amp fuse socket! ... and when the car stalls it wont start in park, but will nuetral. the carb is tighten down good! looks like the original bottom half of the fusible link rotted out by the fire wall so he put a 30amp fuse as the bottom half of the fusible link...it doesnt make sense!! but i took it out and put another bottom part of a fusible link in and i havnt lost power or anything, but when shifting to reverse it still may stall unless i have my foot on the gas ever so slightly ... it almost sounds like its got a mild cam ha but really the low idle is too low and the regular idle is a little above the norm..
