Re: Fuseable Link Fuse Blows in drive an reverse?!!! HELP
[Re: MoparGary7272]
#450834
08/26/09 02:26 PM
08/26/09 02:26 PM
Posts: 7,595 TX , NJ , FL
WINGCARS_6970
TX , NJ , FL
linkage coming incontact and grounding out?.Does battery go dead when car just sits
1969 Daytona 440 L9B410772
1970 Coronet 500 383 Presently owned
1970 Superbird 440 U 166242
1970 Superbird 440 U 174597
1970 Superbird 440-6 V 179697
1970 Coronet RT 440 U 224126
1968 Road Runner 426 J 134509
1970 Daytona Replica 318 G 178701
[Re: Lefty]
#450838
08/26/09 05:04 PM
08/26/09 05:04 PM
Posts: 5,044 At a gas station near you
badblack68
Get rid of those cheap fuses that keep blowing, splice in a heavy guage wire and buy yourself a fire extinguisher.
Nobody gets in to see the wizard! Ain`t no way! Ain`t no how!
[Re: badblack68]
#450839
08/26/09 06:31 PM
08/26/09 06:31 PM
WINGCARS_6970
TX , NJ , FL
Is it a column car where maybe battery cable.Is contacting linkage underhood
[Re: DAYCLONA]
#450845
08/27/09 12:19 PM
08/27/09 12:19 PM
Posts: 4,179 California
mickm
California
Your dealng with 40 year old wiring, that's been hacked on over the years,....why bother!,....just replace everything with new harnesses available from Year One/M&H wiring,.....peace of mine,trouble free from nightmare wiring gremlins
i agree. if you a) don't have the cash for the new harnesses, or b) want the experience of troubleshooting wiring, then go for it.
otherwise you may well save yourself hours if not days of time and frustration.
[Re: MoparGary7272]
#450848
08/27/09 12:41 PM
08/27/09 12:41 PM
WINGCARS_6970
TX , NJ , FL
The neutral safety switch is threaded into the left side of the transmission case .Has a rubber boot with a 3 pin connector
[Re: MNobody]
#450852
08/28/09 03:18 AM
08/28/09 03:18 AM
Posts: 99 NY
MoparGary7272
NY
theres a fusible link AND a 30amp fuse socket! ... and when the car stalls it wont start in park, but will nuetral. the carb is tighten down good! looks like the original bottom half of the fusible link rotted out by the fire wall so he put a 30amp fuse as the bottom half of the fusible link...it doesnt make sense!! but i took it out and put another bottom part of a fusible link in and i havnt lost power or anything, but when shifting to reverse it still may stall unless i have my foot on the gas ever so slightly ... it almost sounds like its got a mild cam ha but really the low idle is too low and the regular idle is a little above the norm..
[Re: stumpy]
#450856
08/28/09 08:43 PM
08/28/09 08:43 PM
Posts: 386 Maryland
reno340
Maryland
You need a fusible link not a fuse in the main circuit. Fusible links are slow blow for a reason. Fuses blow fast when spiked.
My goodness. He blew them both. what does that tell ya!
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
[Re: reno340]
#450857
08/28/09 09:34 PM
08/28/09 09:34 PM
Posts: 99 NY
MoparGary7272
NY
I have a new NSS i got from a buddy still in the box, i looking at the harness.. it looks good.. BUT i didnt pull it off yet, at the time i was noticing the snapped Speedo cable and just replaced it... But if the NSS harness is good, where do i look next?! Yes the car is 38 years old, but its a southern car and a lot of stuff on it is like new, plus the low miles help,.. The Car is tuned Great now, doesnt stall or blow the fuse in reverse ever since the fusible link blew, and shifting into the gears while not moving, it doesnt blow a fuse, instead it does it while driving when RPM have a dramatic change, then like i said the alt. meter goes Frantic and the fuse blows... i must say , i have never seen a fusible link go so quick!!! it drove fine for about 8 miles.. i guess the NSS has to be looked over thouroughly to really know:/ After a fuse blows or the F.L. blew, it WILL NOT start in park just Neutral
[Re: MoparGary7272]
#450858
08/28/09 10:13 PM
08/28/09 10:13 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
You can chase gremlins, or you can fix it the right way. If you have the bucks you can replace everything. If you want to learn something and can work methodically then get a factory service manual, some good wire, tape, an ohm meter, solder and soldering gun and learn how to fix it yourself. Electrical work is a lot like plumbing, and the wiring diagrams in the FSM have never let me down. You got a dead short dealing with the NSS wiring. I've seen factory shift linkages chafe and cut into the wiring before. Also have fixed my share of hack jobs, both under the dash and under the hood. If you have the patience to go one wire at a time, you can fix that old harness.
