Is this a 360 Flywheel?
#450002
08/25/09 09:30 PM
08/25/09 09:30 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
I've seen the 360 externally ballanced flywheels with the 3 large holes bored into them for ballancing, but is this also a 360 flywheel? The guy says its an external balanced 10 1/2" 360 flywheel. Is this another type and can it be used on a 360-A833OD setup in a Duster? Or is this for something else? Thanks
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Is this a 360 Flywheel?
[Re: In_The_Pink]
#450004
08/26/09 05:55 AM
08/26/09 05:55 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I'm going to say it's not a 360 flywheel.
It might be one that was done at a local shop to someones 360 assembly, its not going to look the same as the MP unit.
I'd have the balance checked before using.
[Re: 440Satellite]
#450005
08/26/09 06:56 AM
08/26/09 06:56 AM
Posts: 10,721 North Dakota
6PakBee
North Dakota
Look at all the balance holes that have been drilled in that flywheel. Who knows what it would work with. Unless you want to go through the "mass and vector" approach, I would think the easiest way would be to have a balance shop check it.
[Re: 440Satellite]
#450007
08/26/09 03:31 PM
08/26/09 03:31 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The scallop cut in the OP is common on externally balanced factory flywheels.
[Re: mod5v]
#450010
08/26/09 06:58 PM
08/26/09 06:58 PM
RapidRobert
Your machine shop can spin it & determine how much unbalance it has (external balance) & IF that can be directly matched to the unbalance amt listed in the 360 MP flywheel conversion blueprint then you'll know if the seller was correct that it is balanced for a 360. But w MP poor balancing I would definitely have the whole shebang (re)balanced but at least you'd know if the seller was straight w you.
[Re: RapidRobert]
#450011
08/27/09 06:41 AM
08/27/09 06:41 AM
440Satellite
super gas
super gas
Hazlet, NJ
Ok, thanks for the feedback guys. I just picked up a used 360 short block with 500 miles and a dozen 1/4 mile passes. It has .030 over forged TRW dished (stock looking) piston and chrome rings, looks great, I can still see the cross hatch and theres no ridge, but he didnt have it ballanced. I think I'm going to tear it down and I'll get the whole assemble ballanced useing my 318 flywheel, that way theres no problems.
Butch
1972 Duster
318 4 speed
