Wheel width and section width
#449076
08/25/09 01:59 PM
08/25/09 01:59 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What is the correlation between wheel width and section width of tires?
Say you have a tire that has a section width of 12 inches on an 8 inch wheel. If you put the same tire on a 10 inch wheel how much does it usually change the section width? Make it bigger, smaller, etc?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
