Intake Gaskets #449048
08/25/09 01:18 PM
08/25/09 01:18 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
I am putting a new Edelbrock Performer spread bore with a thermoquad carb. I need to know what kind of gaskets to use and what to do with the space at the to of the heads the intake does not cover. Thank for your help
Re: Intake Gaskets [Re: 70dart318] #449049
08/25/09 01:33 PM
08/25/09 01:33 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
318?
Re: Intake Gaskets [Re: D_C] #449050
08/25/09 01:36 PM
08/25/09 01:36 PM
Streetsboro,Ohio
Streetsboro,Ohio
yes 318
Re: Intake Gaskets [Re: 70dart318] #449051
08/25/09 02:25 PM
08/25/09 02:25 PM
D_C Offline
D_C  Offline
Aren't there instructions (or if Lost, you could go to Edelbrock Online website.)
That said, my "guess" is that a standard Fel-Pro intake-gasket set for the 318 would work, but you should verify.
Re: Intake Gaskets [Re: D_C] #449052
08/30/09 06:37 PM
08/30/09 06:37 PM
Streetsboro ,Ohio
72duster318 Offline
72duster318  Offline
Streetsboro ,Ohio
just a friendly
If you didn't build it yourself, it's not really yours - Tim "the toolman" Taylor
Re: Intake Gaskets [Re: 72duster318] #449053
08/30/09 07:02 PM
08/30/09 07:02 PM
hooziewhatsit Offline
I put these on my 318; finally got the intake sealed compared to the tin gaskets.
http://www.summitracing.com/parts/FPP-1243/
I believe these are for the small ports, so verify with what you have.
What gap at the top of the heads?
Re: Intake Gaskets [Re: hooziewhatsit] #449054
08/30/09 07:19 PM
08/30/09 07:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Go to your nearest NAPA or Carquest and get some of the composite gaskets for it. They will work as well as any. I don't recommend using the tin gaskets though. As for the horse shoe shaped openings they are not ever covered nor meant to be. They are a air dam to help block heat build up and help disipate the heat in the heads between the heat crossover and two adjaceent exhaust valves.
