Smoking out of only one side of dual exhaust. #448974
08/25/09 11:29 AM
08/25/09 11:29 AM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
I have a 74 Duster with a mild 360, headers, and dual exhaust. I do not have an h or x pipe in the system, just straight from engine to rear tips. I drove the car yesterday and noticed it blows smoke from the driver side exhaust. It smells like gas, but I am not sure. Is it possible for the car to be rich only on one side? I have about 1500 miles on the build and it does not use oil.
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: Smoking out of only one side of dual exhaust. [Re: twister360] #448975
08/25/09 11:51 AM
08/25/09 11:51 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't think it's possible to be rich on just "one side" because I think just about every intake, when at WOT, will feed 2 cylinders on each side from 1 circuit of the carb...for example, the front primaries would feed 1, 4, 6, 7. and the secondaries would feed 2, 3, 5, 8. or something similar to that--with most dual planes anyway....single planes would be more like front primaries on carb feed front 4 cylinders, and the secondaries feed the back 4 cylinders...
but, I don't know for sure, if the carb is gummed up or something it could be possible that one venturi is running rich, making 1 or 2 cylinders richer than the rest...
what color is the smoke? Blue/Grey? Black? White?
**Photobucket sucks**
Re: Smoking out of only one side of dual exhaust. [Re: twister360] #448976
08/25/09 11:55 AM
08/25/09 11:55 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what color smoke? white=water, blue=oil, black=rich
if it's a dual plane manifold, typically one side of the carb feeds 1/2 the cylinders. on an eddie RPM or air gap, the DS of the carb feeds 1,7,4,6 and the pass side feeds 3,5,2,8 (looking at the pics on summit)
2017 Grand Cherokee Overland
Re: Smoking out of only one side of dual exhaust. [Re: patrick] #448977
08/25/09 12:06 PM
08/25/09 12:06 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
intake gasket or surface... dan
Re: Smoking out of only one side of dual exhaust. [Re: ph23vo] #448978
08/25/09 12:57 PM
08/25/09 12:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
could be sucking oil on one bank.
Coming soon!!!!
Re: Smoking out of only one side of dual exhaust. [Re: patrick] #448979
08/25/09 01:36 PM
08/25/09 01:36 PM
Houma, Louisiana
Houma, Louisiana
I have a dual plane air gap. The smoke is blackish and smells somewhat of gas. Any test to check out the problem? Thanks
Re: Smoking out of only one side of dual exhaust. [Re: twister360] #448980
08/25/09 03:39 PM
08/25/09 03:39 PM
CT USA
N
Nick Mineau Offline
Nick Mineau  Offline
N
CT USA
pull th plugs and note the diffrence inleft and right . if it is a fuel problem on side the plugs on that side will be black/charcol looking. they should be a gray/brown
Re: Smoking out of only one side of dual exhaust. [Re: twister360] #448981
08/25/09 09:39 PM
08/25/09 09:39 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
hmm...only thing I can think of would be an intake manifold gasket not sealing, causing a vaccuum leak on one side, leaning out that bank of cyls?
Re: Smoking out of only one side of dual exhaust. [Re: patrick] #448982
08/26/09 02:38 PM
08/26/09 02:38 PM
Houma, Louisiana
Houma, Louisiana
Could I spray starting fluid along the manifold gasket and see if it effects the running of the engine?
