Approx piston weight..? #448314
08/24/09 07:25 PM
08/24/09 07:25 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
Hiya, Can anyone provide some guidance on the approximate weight of the following Piston Spec:
JE Forged 4.500 bore
1.03 tapered pin, double spiro's
.043, 1/16, Std oil ring
65 cc dome
1.38" compression height (for use with 7.1" rods)
I am working thru the specs for rods, crank, pistons etc before ordering and want to get the weights right so that that minimal balancing is required.
Hope you can help
Darren
Darren Beale
Keith Black Racing Engines®
Re: Approx piston weight..? [Re: Keith Black®] #448315
08/24/09 08:16 PM
08/24/09 08:16 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
No one can tell you that. It will vary drastically on the forging it is machined out of.
My guess if it is a LW forging........500-550 grams.
SRT DEMON ONE SEAT
Re: Approx piston weight..? [Re: Ron Silva] #448316
08/24/09 09:14 PM
08/24/09 09:14 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't have anything to compare it to. But from this, a dome hemi piston might be 800+ grams.
http://www.jepistons.com/cat/je/auto/mopar/426_hemi.shtml
Re: Approx piston weight..? [Re: Ron Silva] #448317
08/25/09 12:20 AM
08/25/09 12:20 AM
QLD Australia
QLD Australia
Thanks... I will contact JE.
Darren Beale
Re: Approx piston weight..? [Re: Keith Black®] #448318
08/25/09 11:42 AM
08/25/09 11:42 AM
NC
440Jim Offline
440Jim  Offline
NC
Let us know what they say.
Re: Approx piston weight..? [Re: 440Jim] #448319
08/25/09 11:51 AM
08/25/09 11:51 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have a similar Wiseco Pro Tru Piston. This piston has a 100cc dome, and .990 wrist pins, Comp height is 1.29. This piston is 729 grams. So I would imagine yours will be in this ball park. Yours has a smaller dome, and larger Pin, mine ha s shorter CH etc.
Im going to guess they will be within 20 grams of each other, but who know....
Post when you find out
Re: Approx piston weight..? [Re: Keith Black®] #448320
08/25/09 12:17 PM
08/25/09 12:17 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Here is the spec sheet on my CP pistons. Less dome and 990 pins.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
