426 hemi rod #448225
08/24/09 06:18 PM
08/24/09 06:18 PM
New England
Tech Instructor Offline OP
New England
What rod length would you use with 4.375 stroke crank?
Re: 426 hemi rod [Re: Tech Instructor] #448226
08/25/09 08:52 AM
08/25/09 08:52 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: 426 hemi rod [Re: Tech Instructor] #448227
08/25/09 05:33 PM
08/25/09 05:33 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Depends.....
Re: 426 hemi rod [Re: CRE2004] #448228
08/29/09 07:48 AM
08/29/09 07:48 AM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
I'm building a hemi with a 4.375.Thinking of 6.86 or 7.01
Ain't nuthin like a HEMI !
Re: 426 hemi rod [Re: Mulehead] #448229
08/29/09 09:04 AM
08/29/09 09:04 AM
JohnRR Offline
JohnRR  Offline
One wants to keep the piston small , but not to small that it rocks in the bore. Going to a 4.375 stroke I wouldn't be considering a stock length rod because the CH of the piston will GROW .625 and a hemi piston is already heavy, you'll just make it heavier.
You want the rod to be long enough that the piston doean't come to far out of the bore and get hit by the counterweights on the crank.
Re: 426 hemi rod [Re: Tech Instructor] #448230
08/29/09 11:07 AM
08/29/09 11:07 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
7.1 is the typical rod for a stroker. Your compression height would be BH - RL - 1/2 stroke - Deck = 1.423
Block height: 10.72 (assuming the decks have been surfaced)
Rod Length: 7.1
1/2 stroke: 2.1875
Deck: .010 (leaving some room for later machining)
This puts the center of the pin 1.423" down which leaves enough room for rings yet keep the pin out of the oil groove.
