8.75 rear pinion splines
#448086
08/24/09 02:23 PM
08/24/09 02:23 PM
Posts: 84 NC
Badfish67
NC
Which is a stronger pinion spline, the 10 or the 29...or does it not matter?
1967 Barracuda
360ci/727
9.723ET @139.44mph
Re: 8.75 rear pinion splines
[Re: S/ST 3040]
#448089
08/24/09 05:04 PM
08/24/09 05:04 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Typically, fine spline is always stronger..........unfortunately, not the weak link on an 8 3/4" rear end so, in this case even though the 29 spline is technically stronger, it doesn't matter.
I would, and do, use the "742" case as it has the thickess pinion stem at the yoke If your going to put a lot of power to this third member with good traction make sure and replace the stock driver side carrier cap with a steel cap from Mark Williams or Summer Bros.
[Re: Cab_Burge]
#448090
08/24/09 05:21 PM
08/24/09 05:21 PM
Posts: 84 NC
Badfish67
NC
Thanks for the info, but I think your wrong about the 742 being the thickest. The 742 has a 1 3/4" pinion shaft and the 489 has a 1 7/8" shaft.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Badfish67]
#448091
08/24/09 05:29 PM
08/24/09 05:29 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
You're talking about the other end of the pinion. Cab is talking about the yoke end, where the nut goes, the shaft/Bearing surface is larger in that area on a 742 vs a 741 or 489.
[Re: RobX4406]
#448092
08/24/09 06:31 PM
08/24/09 06:31 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Dr Diff, has posted pics of them all in the tech section here.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
