5.7 Oil Pans
#447935
08/24/09 10:13 AM
08/24/09 10:13 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Anyone know of a center sump pan for the 5.7 Hemi BESIDES Milodon? I have seen the custom aluminum one from Bouchillon and it is VERY nice but I don't want to spend $500 on an oil pan!
Driving modern convenience in classic beauty
Re: 5.7 Oil Pans
[Re: ZIPPY]
#447937
08/24/09 10:55 AM
08/24/09 10:55 AM
What's the story on 5.7/ 6.1 pans. Are they OEM aluminum as opposed to stamped steel?
They different from previous engines I guess?
Re: 5.7 Oil Pans
#447938
08/24/09 11:09 AM
08/24/09 11:09 AM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Car pans are cast aluminum. Truck pans are stamped steel, but not ordinary steel (that would be too easy). They're stamped from "quiet steel". Basically a laminate, 2 layers of steel with plastic sandwiched between to prevent the part from resonating. It works, but the oil inside the pan also dampens alot of resonance by itself.... Here's a link to explain better: http://www.quietsteel.com/quietsteel.htmlMany of us would assume we could cut the sump off a truck pan and relocate it, but imagine the melted plastic everywhere, contaminated welds, etc.
Re: 5.7 Oil Pans
[Re: ZIPPY]
#447941
08/24/09 12:37 PM
08/24/09 12:37 PM
Posts: 387 Almont, MI.
gdemon
Almont, MI.
I have the mopar pan on mine. I think it was 382.00 with the pick up and dipstick from the dealer. I have had mine on for about 1000 miles with no sealer and have no leaks.
Jerry
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
Re: 5.7 Oil Pans
[Re: gdemon]
#447942
08/24/09 12:56 PM
08/24/09 12:56 PM
ZIPPY
S.E. Michigan
That's cool you had good luck with it. You got an excellent price on that.
Mine, laid on the block, can be rocked back and forth end to end about 25 or 30 thou....there is a high spot in the rail somewhere in the center....yes the bolts with "smash" it down somewhat, but....I only want to do it once so I'm going to use sealer.
And on top of that, it's probably going into a C body, and I might need to cut/notch it for steering linkage clearance too....etc...so maybe I better check and see what fab work I have to do before I try to install it.
The one Milodon one I checked out could be rocked back and forth about the same as the Mopar pan (only diagonally, so it was warped out of the box in a slightly different manner). It did look nice but wasn't what I'd call a gem....Yes it would work, but I'd probably use sealer on it too.
The pan rails are all fabricated, so one is going to be alot different from the next unfortunately...
Re: 5.7 Oil Pans
[Re: ZIPPY]
#447943
08/24/09 01:02 PM
08/24/09 01:02 PM
gdemon
Almont, MI.
Thats true nothing worse then having a leak. The factory pan did have sealer where the timer cover met the pan and where the rear main seal met the pan. I did by my pan about 18 months ago so maybe the price has gone up.
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
