Steam holes aluminium Hemi Block World Prod.. #447658
08/23/09 11:28 PM
08/23/09 11:28 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
The block deck has no steam holes... should I drill some to match the gasket ?
if so how..? dia?
I have stage V heads... drill in the heads to match?
Whats this with steam holes anyway?
Darren
Darren Beale
Keith Black Racing Engines®
Re: Steam holes aluminium Hemi Block World Prod.. [Re: Keith Black®] #447659
08/24/09 12:25 PM
08/24/09 12:25 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
if so how..? dia?
Darren
Darren,
Here is part of an email I got from Tim Banning, when I was ordering parts for my build.
It may clear things up for you.
Hi Mark, the bare Stage V replacement heads price out at $0000pr bare. I need you to specify which block you intend to run, so we can machine the correct water passages and steam holes to match. We also need to know your application/cam choice to price out assembled and/or ported heads with appropriate valve sizes and spring/retainer combos. We stock Stage V rockers, OEM rocker assemblies, KB, World Product aluminum and or cast iron blocks. Our CNC replacement heads can be finish machined from mild to wild depending on hp requirements. Let us know. Tim @FHO
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Steam holes aluminium Hemi Block World Prod.. [Re: Keith Black®] #447660
08/24/09 12:30 PM
08/24/09 12:30 PM
an8sec70cuda Offline
I know I had to have the steam holes in my MP heads welded up so I could redrill the holes so they'd line up with the holes in the deck of my KB block. The KB block has it's own specific head gasket also...not sure about the World blocks. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
