Rear shock ????????? #447612
08/23/09 10:34 PM
08/23/09 10:34 PM
In the 8's
FY1TA Offline OP
FY1TA  Offline OP
In the 8's
Is there a big benefit between single and double adjustable rear shocks ? Looking at buying a new set of Afco's and would like to know . Thx
Re: Rear shock ????????? [Re: FY1TA] #447613
08/23/09 11:27 PM
08/23/09 11:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What type of rear suspension
Re: Rear shock ????????? [Re: FY1TA] #447614
08/23/09 11:27 PM
08/23/09 11:27 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
In a word, YES.
Standard shocks you have no control over the compression or extension.
SA, you can adjust how fast they extend but not compress.
DA, you can really fine tune you shocks to suit them to what you need.
Re: Rear shock ????????? [Re: MR_P_BODY] #447615
08/23/09 11:34 PM
08/23/09 11:34 PM
In the 8's
FY1TA Offline OP
FY1TA  Offline OP
In the 8's
Ladder bar .
Re: Rear shock ????????? [Re: FY1TA] #447616
08/24/09 12:15 AM
08/24/09 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ladder bar .
I'm assuming you have singles now and want to know
if the DA are better. With a ladder bar you are really
trying to separate the body from the rear suspension
so you need a good adjustment on extension. The DA
adjustable will give you the control for the extension
but it also gives you the compression adjustment for
the down track(thats where you might need the DA)
but to me the DA doesnt help the off the line
I'm talking on a ladder bar now.... with a 4-link
the DA can help(depends on the IC settings)
