Re: 1967 GTX tires...how big with out cutting? pics?
[Re: joshking440]
#447243
08/23/09 05:37 PM
08/23/09 05:37 PM
Posts: 401 Ohio, USA
Dr-Dave2
Ohio, USA
I put some 9.0" X 28" slicks on my 66 Coronet, using a 15x7, 4.25" back space police rim. Should be about the same as a 67 GTX. Its pretty tight but no cutting required. 275/60/15 street radial is almost exactly the same size as the 9X28 slick. If you want to go even taller ( Like 29" tall ) I see no reason a 255/70/15 wouldn,t fit on the same size and B.S. wheel, just half an inch closer to the front edge of the wheel lip and a slight bit narrower cross section width.
[Re: moparguy7074]
#447245
08/23/09 08:34 PM
08/23/09 08:34 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I put 245/60-15's on my 67 Satellite. They fit fine, and actually still leave quite a bit of room. I'm sorta wishing now I had gone 255/70's. I'm positive they'd fit just fine. 15x7's with 4-1/4" bs seem to be the right wheel. They center perfectly in my wheelwells.
[Re: StealthWedge67]
#447246
08/24/09 10:19 PM
08/24/09 10:19 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
