'70 Duster Rallye Mirror Remote Position?? #447035
08/23/09 12:54 PM
08/23/09 12:54 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Got a buddy who wants to add rallye mirrors to his '70 Duster.It has just a manual driver side mirror now.My question is,where is the opening located on the drivers side inner door for the remote control? Also does anyone have the measurements for correct placement of both left and right rallye mirrors?Thanks!!
Re: '70 Duster Rallye Mirror Remote Position?? [Re: 44D6PAKCUDA] #447036
08/24/09 10:35 PM
08/24/09 10:35 PM
Re: '70 Duster Rallye Mirror Remote Position?? [Re: 44D6PAKCUDA] #447037
08/25/09 01:52 PM
08/25/09 01:52 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
on my 73 dart all the holes where in drivers door. i put the passenger side in same location as drivers.
Re: '70 Duster Rallye Mirror Remote Position?? [Re: 05dakota] #447038
08/25/09 04:35 PM
08/25/09 04:35 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I did the same and they look and function great!
Re: '70 Duster Rallye Mirror Remote Position?? [Re: T2R9] #447039
08/25/09 08:20 PM
08/25/09 08:20 PM
Well I got a picture of where the mirror remote goes,just left of the Duster inner door emblem.I am looking for exact location so I can drill a hole in the upper door frame and also looking for correct diameter of the hole that the remote comes thru.I know I have a little room to play with with the mirror remote mounting nut,but want to make sure it's not too big either.Thanks for any help !!
Re: '70 Duster Rallye Mirror Remote Position?? [Re: 44D6PAKCUDA] #447040
08/25/09 09:29 PM
08/25/09 09:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
These are both originals. Drivers side first. Measuring from the edge of the doors forward most point along the top body line of the car back, it's precisely 17.50" on the center of the retention screw.
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447041
08/25/09 09:30 PM
08/25/09 09:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
#2
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447042
08/25/09 09:32 PM
08/25/09 09:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
1.00" dead nuts to the screw CL from the peak edge
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447043
08/25/09 09:33 PM
08/25/09 09:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Remote is hard to measure. I measured from the top of the forward door sill point rearward
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447044
08/25/09 09:35 PM
08/25/09 09:35 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
As measured down from the top transition (which is a bit rounded)
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447045
08/25/09 09:36 PM
08/25/09 09:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
And from the "Duster" door emblem forward, the top of the bezel is just about level with the emblems upper edge
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447046
08/25/09 09:37 PM
08/25/09 09:37 PM
Scott-Thanks just what I was looking for.Can you get a measurement from the top the door edge to the center of the remote hole? Also any idea what diameter the hole opening is? Thanks again!!
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447047
08/25/09 09:37 PM
08/25/09 09:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Be patient young man!
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447048
08/25/09 09:38 PM
08/25/09 09:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It's 15.50" from the door edge back to the CL of the screw hole
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447049
08/25/09 09:41 PM
08/25/09 09:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Same 1.00"in as the drivers side.
The remote hole? I don't know, just drill it until the part goes through and it will be big enough, BTW, doors without the hole for the remote are actually getting hard to come by, you might want to consider getting a spare door....Just a thought before you modify it.
Re: '70 Duster Rallye Mirror Remote Position?? [Re: ScottSmith_Harms] #447050
08/25/09 09:41 PM
08/25/09 09:41 PM
I'm chuckin' up the drill already!!!
