wiped cam? #446757
08/23/09 08:02 AM
08/23/09 08:02 AM
West Tennessee
rbstroker Offline OP
West Tennessee
Is there any way to check for a bad hydraulic flat tappet cam lobe without removing the intake and actually looking at the lobes?
This is the land of the free because of the brave
Re: wiped cam? [Re: rbstroker] #446758
08/23/09 08:22 AM
08/23/09 08:22 AM
Pull the valve covers and check the lift at the rockers. If you have a dial indicator even better.
