Re: CUT THE BULL !
[Re: EJ440]
#446683
08/25/09 11:31 AM
08/25/09 11:31 AM
Posts: 351 michigan
64ssmax
michigan
heads are 69.9 cc 13.1 comp. converter is a 5500 coan made for motor. How did you build your convertor with no dyno sheets? ![](/ubbthreads/images/graemlins/Twocents.gif)
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Re: CUT THE BULL !
[Re: camastomcat]
#446687
08/25/09 04:50 PM
08/25/09 04:50 PM
Posts: 1,527 Michigan
GoDartGo
by the lack of any more post, I think EJ440 has taken his motor apart ![](/ubbthreads/images/graemlins/wrench.gif) and is sitting in a $2500 pile of swap meet ![](/ubbthreads/images/graemlins/bawling.gif) gems.
Re: CUT THE BULL !
[Re: GoDartGo]
#446688
08/25/09 05:53 PM
08/25/09 05:53 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
by the lack of any more post, I think EJ440 has taken his motor apart and is sitting in a $2500 pile of swap meet gems.
From EJ440,s post history hes not a big talker. The barrage of questions probably scared him away.
He inquired about engine builders before and "Hensly racing" engines was recommended, so maybe that was the engine builder. Hes also about 6 hours away from him, ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
With the limited info given there is not info to blame any engine builder IMO.
The engine is definately not up to snuff and running like it should. But that could be for a number of reasons as already stated. It could be as simple as two plug wires crossed or some simple timing or jetting issues,etc,etc.
Without anymore quality input/feedback from EJ440 I guess we'll never know.
Back in 95 when I put my new MP 484cam 440 combo together it wouldnt even spin the tires the first time out. After working out the bugs, 11.75 ET
After a few more years of dialing in the combo and a MP 509 cam, 10.47 ET.
My point is, to check all the basics before condeming the motor and its builder. mike ![](/ubbthreads/images/graemlins/thumbs.gif)
Also while EJ440,s car is not running as it should, she doesnt run bad and it sure looks Nice ![](/ubbthreads/images/graemlins/beer.gif)
Re: CUT THE BULL !
[Re: Sport440]
#446689
08/25/09 08:33 PM
08/25/09 08:33 PM
EJ440
I just got back from droping the car off at my local moparmam. would had him build it from the begging but the machine shops around here just plain suck . he said that the car is just plain lazy. he is going find out whats going on. Im not a motor guy but a paint & body guy . just never got in to building short blocks. and about the converter ? . without a dyno sheet they ask for cam lift, cam@50, bore & stroke ,compression, est hp. I did all the things the builder said to do. "I'm not here to BASH OR BAD MOUTH anyone". I have been spending a lot of money and not going any where . tired of beating the hell out of my car and not going any where. ![](/ubbthreads/images/graemlins/flame.gif) just want to unlock my 800 hp .
Re: CUT THE BULL !
[Re: EJ440]
#446691
08/26/09 12:41 PM
08/26/09 12:41 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I just got back from droping the car off at my local moparmam. would had him build it from the begging but the machine shops around here just plain suck . he said that the car is just plain lazy. he is going find out whats going on. Im not a motor guy but a paint & body guy . just never got in to building short blocks. and about the converter ? . without a dyno sheet they ask for cam lift, [Email]cam@50[/Email], bore & stroke ,compression, est hp. I did all the things the builder said to do. "I'm not here to BASH OR BAD MOUTH anyone". I have been spending a lot of money and not going any where . tired of beating the hell out of my car and not going any where. just want to unlock my 800 hp .
In my experience very seldom is the converter correct out of the box-any box. That's one place I would look. I also think that your cam timing is incorrect and you should keep advancing it but when you do this you have to keep track of your p/valve clearance. Good luck.
Re: CUT THE BULL !
[Re: stroked470]
#446694
08/26/09 01:54 PM
08/26/09 01:54 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Good luck with it, things will come around. If you keep researching the posts on here, you will gain valuable insight from those going fast with similar packages. That was the key for me. My car went from 9.50s to 8.70s by what I gleaned from these guys.
