Re: CUT THE BULL !
[Re: NITROUSN]
#446623
08/23/09 11:47 AM
08/23/09 11:47 AM
EJ440
it was put together whit his proving combo.
Did you assemble the motor or did the engine builder assemble it?
he did.
Re: CUT THE BULL !
[Re: EJ440]
#446625
08/23/09 11:52 AM
08/23/09 11:52 AM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
no dyno sheet on this motor. it was put together whit his proving combo. header are 2in hooker fender well .msd 7 al2. fuel punp is aeromovive 1000.i shift @6800b traps about 7000 .compression is 13;1 69cc head. old motor was a 30 over 440 stage 6 heads 76cc .cam was isky 660 [Email]282@50.[/Email] 1050 dom . the same 2in headers.
Iam guessing its a glide but a shift @ 6800 and another 1/8 mile and it only makes 200 RPM's more? That dont seem right.
Re: CUT THE BULL !
[Re: weedlayer]
#446626
08/23/09 11:53 AM
08/23/09 11:53 AM
Quicktree
why should he have to test it??? he paid 15 g's for a motor that does not perform. If I went from my current 600 ponies to 800 ponies even in the same set up it better do better than run the same number. besides, he all ready put it to the best test there is. He has time slips and they suck. Gonna take more than fiddlefarting around with cam timing to find what he's missing. I hate it when I see what people spend good money for and the results they get. I am done.
Re: CUT THE BULL !
[Re: weedlayer]
#446629
08/23/09 11:58 AM
08/23/09 11:58 AM
I'm REALLY curious who this "supposed" guru is that doesn't even provide a dyno sheet, for a $15,000 engine? That's just ludicrous! RandyB
Re: CUT THE BULL !
#446631
08/23/09 12:00 PM
08/23/09 12:00 PM
Quicktree
no kidding, I wouldn't even make a post like this until I was ready to put that info out and exhausted all efforts with the builder to solve the problem.
Re: CUT THE BULL !
[Re: EJ440]
#446633
08/23/09 12:04 PM
08/23/09 12:04 PM
Quicktree
you all have heard of him and its not INDY .
well are you going to play games or tell us? have you even talked with him about this and asked him to fix the problem? if it turns out to be something other than the motor what then?
Re: CUT THE BULL !
[Re: Quicktree]
#446634
08/23/09 12:10 PM
08/23/09 12:10 PM
Posts: 705 Michigan
Hemiroid
Exactly! Hard for me to believe someone pays $15k for a engine with no dyno info? If that's the case, you're to blame as much as the engine builder. No way in hell I'm taking delivery of that engine without it being pulled and tested with dyno sheets. As Quicktree asked, have you even spoke to the engine builder? What did he say? Something just doesn't sound right here.
Re: CUT THE BULL !
#446635
08/23/09 12:12 PM
08/23/09 12:12 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
500" 440-1 combos are popular,prooven. I've built several 760 to 820hp for much less than $15000. That said I'd leak it before U pull it. If it leaks OK then plan revenge. Car should run mid 9's all day.
The little old lady from Pasadena is back!
Re: CUT THE BULL !
[Re: EJ440]
#446641
08/23/09 12:53 PM
08/23/09 12:53 PM
Quicktree
NOT GOING TO BEATUP ANYONE YET.just looking for ideals or help on what could be worng on my end .and yes i have talked to him bout it. he is not much help.its getting to the point you cant trust anybody.i guest I'm going to take it out. take it a part get some books and try and do it my self.
Big mistake, once you open it up your done. all the books in the world wont help at this point.
