Re: holley 4160 question (newbie type question)
[Re: 1_WILD_RT]
#446600
08/23/09 02:02 AM
08/23/09 02:02 AM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Also, when you "fan" the throttle-blades, they aren't supposed to open (or open very much,) yet they WILL work when they are supposed to, under a load at full-throttle. This is from the Holley.com website: Quote:
QUESTION: I can rev the engine when it is in park and the secondaries will not open. Why is this?
ANSWER: The secondaries will not open by free revving the engine. The engine needs to be under a load before they will open. If you are still uncertain if they are opening or not you can take a normal paperclip and clip it onto the secondary diaphragm rod. You will then push it up against the bottom of the secondary diaphragm housing, now you will need to go out and drive the vehicle. When you return you will be able to look at the position of the paperclip on the rod. If it is lower on the rod then you can tell the secondaries opened and how far they opened. This is useful in determining if you need a heavier or lighter secondary spring.
If you're willing to invest a little time, you can learn a bunch fast here:
How your Holley Carb Works
Holley Carb FAQ's
Holley Tech Library
