1.130" ID, 3/8", 7* valve spring retainers
#446345
08/22/09 05:11 PM
08/22/09 05:11 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Beside HUGHES ( PN 1256 ), what other vendor does have that measure on retainers that could keep the stock installed heigh OR maybe add some stationary pressure without use shims ?
and on a similar price ( or cheaper if posible )
Re: 1.130" ID, 3/8", 7* valve spring retainers
[Re: NachoRT74]
#446347
08/23/09 02:26 PM
08/23/09 02:26 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
You may have to research several of the cam companies to see what they offer. The Hughes 1256 Retainer is 3/8" stem, 7-degree lock, +0.075" install height, 1.375" outer diameter, 1.130" middle step diameter, and 0.730" inner diameter, and cost $62.00. Are you looking for a retainer with the same diameters, but without the increased install height? Which valve spring is this for? If it is for something like the 1106 spring the spring is a single with damper, 1.540 OD, 1.130" ID. I think it would be easier to just shim the spring ? Manley has a 1.130" 23636-16 standard height retainer, but it is for 10-degree locks. The retainers are $50, but you would need the 10-degree locks too (Comp 612-16 are $20.00.) A Comp 749-16 may work $49.25 (1.125" id), but it is also for 10-degree locks.
I just found this one that may also work, Lunati 75713LUN. This is for 7-degree retainers, and is 1.500"x1.125"x0.700", and costs $44.95.
FWIW, I priced these from Summit.
[Re: 451Mopar]
#446348
08/23/09 02:36 PM
08/23/09 02:36 PM
NachoRT74
Valencia, España
exactly, and since valve springs are used I'm getting 120 PSI ( seller acclaimed just 4K miles on them, so trusted ) at installed height specs by Hughes ( 1.880", what should it be 150 )
but when I got them ( at Carlisle last year ), IN MY IGNORANCE never thought on retainers.
I'm just watching another options.
[Re: NachoRT74]
#446349
08/23/09 02:56 PM
08/23/09 02:56 PM
NachoRT74
Valencia, España
Lunati does look a good option, but doesn't say about installed height
will 1.125" be a noticeable diff from 1.130" to get worried ?
[Re: NachoRT74]
#446350
08/23/09 03:02 PM
08/23/09 03:02 PM
451Mopar
Aurora, Colorado
As far as I can tell the Luanti retainers are stock install height, but you may have to call them to verify. You may also have to let them know the valve stem diameter? I think the extra 0.005" clearance will be OK. I would ask on the race section to see what the pros say?
[Re: 451Mopar]
#446351
08/23/09 03:20 PM
08/23/09 03:20 PM
NachoRT74
Valencia, España
ok, great!! thanks for open the options to me... Since is not for race and really for street, I don't think .005" clearence will be something to worry, but will ask around. Now... WHAT'S the stock installed height of the 452 heads assembly with stock on everything ? ( lock and valves ) I mean... hughes says 1.880" installed height for that spec ( and that was teh test I made ), but I don't know if thats the Original height on the pure stock assembly... I read somewhere stock height is around 1.83" to 1.86" and that will mean will add some pressure on this used springs ? dunno if important but still some pressure add, and if so, then Lunati retainers are even more a better option ( beside the price by Summit, althought the clearence )
[Re: NachoRT74]
#446352
08/23/09 03:27 PM
08/23/09 03:27 PM
NachoRT74
Valencia, España
I'm also assuming the stock valve locks are 7º... right ?
