Page 3 of 6 1 2 3 4 5 6
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446195
08/23/09 05:10 PM
08/23/09 05:10 PM
cataclysm80 Offline OP
This shows which way the bracket between the radiator support and the K frame went. Over the K frame, under the radiator support, big end towards the K frame.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446196
08/23/09 05:16 PM
08/23/09 05:16 PM
This is the power brake setup I was running at the time.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446197
08/23/09 05:18 PM
08/23/09 05:18 PM
Here's how it looked from inside the car. There's lot's of little reference type stuff in this pic if you're looking for something in this area.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446198
08/23/09 05:19 PM
08/23/09 05:19 PM
Same thing, different angle
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446199
08/23/09 05:26 PM
08/23/09 05:26 PM
This is the brake T and line routing. I bent the lines a little when installing the brake booster and new master cylinder, but this should be correct for a four wheel drum brake car before Jan 1 1970. I couldn't be positive on cars built after that because the brake T's/metering valves/proportioning valves changed at that point.
You can also see the battery cable wiring tab in this pic. It screws onto the frame rail and is often missing on cars I see at shows.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446200
08/23/09 05:31 PM
08/23/09 05:31 PM
Here's how these brackets to the fender headlight bucket were mounted. They're marked R & L. I think they should be on 70 & 71 Challengers, but 72-74 used a different headlight bucket setup that was sort of built into the grill.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446201
08/23/09 05:35 PM
08/23/09 05:35 PM
Headlight Adjuster & Headlight Bucket Spring locations
(note the extra holes in this fender. It's a late 71 fender.)
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446202
08/23/09 05:38 PM
08/23/09 05:38 PM
This is the correct location & orientation of the front valance clips on the fender.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446203
08/23/09 05:40 PM
08/23/09 05:40 PM
This is the correct location & orientation of the grill top & end clips on the fender.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446204
08/23/09 05:42 PM
08/23/09 05:42 PM
This is the correct location of the fender clips that hold it onto radiator support, but they're on backwards in this picture. They should be facing the other direction. Ooops!
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446205
08/23/09 05:43 PM
08/23/09 05:43 PM
The front bumper brackets come apart into four pieces, so here is how they're supposed to go onto the car.
Note that mine are very yellow. Is this the correct color, or are these over the counter parts or something?
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446206
08/23/09 05:46 PM
08/23/09 05:46 PM
Here's how the door hinges and rear upper fender bracket go onto the car.
You can also see where some seam sealer was applied from the factory.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446207
08/23/09 05:50 PM
08/23/09 05:50 PM
Here's where the rear window centering clip mounts. This centers the rear window vertically in the opening. A trim clip is not used in this location.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446208
08/23/09 05:52 PM
08/23/09 05:52 PM
Here's how the 1970 Challenger only rear valance brackets mount to the car.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446209
08/23/09 05:55 PM
08/23/09 05:55 PM
Here are the outboard rear valance brackets for the same 70 Challenger only setup. The angled corners faced outward on each side of the car.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446210
08/23/09 05:56 PM
08/23/09 05:56 PM
Here is how the rear bumper brackets go onto the car. You wouldn't want those on upside down.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446211
08/23/09 06:00 PM
08/23/09 06:00 PM
This shows the remains of the jacking instruction sticker.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446212
08/23/09 06:02 PM
08/23/09 06:02 PM
The trunk latch bar has one edge curved up and one edge curved down. Here's how it was installed on this car.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446213
08/23/09 06:06 PM
08/23/09 06:06 PM
This shows the hinge backing plate inside the trunk lid. It is held on with a screw.
You can also see one of the two trunk lid body plugs. These seem to often be either missing or painted body color at shows. They should be plain black plastic.
Tav
Re: Tav Challenger T/A Clone [Re: cataclysm80] #446214
08/23/09 06:09 PM
08/23/09 06:09 PM
This shows the factory sound deadener that was applied to the quarter panels before they were installed on the car.
It also show some wire routing.
Tav
