Oil and filter for a SB #446031
08/22/09 01:19 PM
08/22/09 01:19 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I just purchased a 318 with j heads runs High 12's. The oil looks pretty bad The previous owner ran straight30W at 50 lbs of Oil pressure. I ran a Wix filter on my 440. Could someone give me a part number for a filter and what weight oil do you guys like to run in your SB'S
Re: Oil and filter for a SB [Re: flatiron] #446032
08/22/09 02:02 PM
08/22/09 02:02 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use the same filter. I would run 15/40 Rotella.
Re: Oil and filter for a SB [Re: flatiron] #446033
08/22/09 02:14 PM
08/22/09 02:14 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Or run the 30wt Rotella.
Nautilus Racing-
