Chassis guys what is the best ..........way
#446009
08/22/09 12:28 PM
08/22/09 12:28 PM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
to limit front end rise with limiters? "LA PUTITA" was pulling to the right when coming off the break. My chassis guy decided to take all the slack out of my limiters which is a length of 1/4 inch cable though the shock tower and down to the frame fastened with those U clamps from home depot. The fix worked for keeping the launch straight but the force pulled the cable right through the U clamps!
Diego
Re: Chassis guys what is the best ..........way
[Re: Diego_Ted]
#446011
08/22/09 01:12 PM
08/22/09 01:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Diego
Make sure you have at least 2 clamps and there is another thing called a a linemans clamp... they crimp on the cable(usually made out of thick copper/brass
[Re: Diego_Ted]
#446013
08/22/09 02:06 PM
08/22/09 02:06 PM
Posts: 2,511 PA
moparacer
PA
Cant the going left/right problem be addressed with preload Ted?
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Diego_Ted]
#446015
08/22/09 04:48 PM
08/22/09 04:48 PM
Posts: 43,211 Bend,OR USA
Cab_Burge
I forgot to ask if your using cable clamps with U bolts that fit into a U shape female end with serartion inside the big end? If not get some of them at a good hardware store, we use to use two on each end. What size cable are you using now?
[Re: Cab_Burge]
#446016
08/22/09 06:32 PM
08/22/09 06:32 PM
Posts: 825 LENOX , MI
KMPX2
mopar addict
mopar addict
LENOX , MI
And make sure you put them on the right way. Remember the old saying never saddle a dead horse.
[Re: Diego_Ted]
#446017
08/22/09 06:57 PM
08/22/09 06:57 PM
MR_P_BODY
Thanks Cab and Mr. P, I will go and see what I can find!! Mr. P how you feeling? Good I hope.
Diego
I'm doing great... thanks for asking
[Re: MR_P_BODY]
#446018
08/22/09 08:38 PM
08/22/09 08:38 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Might not hurt to put a couple of shock biscuits on the limiters to soften the stop. I used 3/8 eye bolts (welded shut!), two bayonet style biscuits for cushion, and the steel washers with nylock nuts to make it easy to adjust at the track. Softens the sudden stop of the front suspension.
[Re: gregsdart]
#446019
08/22/09 11:08 PM
08/22/09 11:08 PM
MR_P_BODY
I dont like having it hit solid all of a sudden, to me it upsets the chassis.... let it have a little cushing
[Re: dvw]
#446022
08/23/09 09:48 AM
08/23/09 09:48 AM
MR_P_BODY
I know a lot of guys use a solid bolt in the original bump stop location. Has anyone ever tried this with washers and shock rubbers around both sides of the frame with the bolt running through them? It seems this would be easier than cables. My buddys new 09 S/S Mustang has rods welded to the end of the cables. The rod comes up through a tube in the inner fender. There is a pin going through holes in the tube and rod to secure them. It has various holes for quick adjustments. So far it has worked very well. Doug
Years ago I use to do basically that, I use to use different durometer rubber washers stacked up to slowly squash them but the softer durometer rubber didnt live all that long so I found some truck rear end snubbers and bolted them in place on the front. I would grind the rubber to adjust the movement of the arms
[Re: MR_P_BODY]
#446023
08/23/09 10:01 AM
08/23/09 10:01 AM
gregsdart
The biscuits are the rubber parts that come from the top end of a mopar front shock. I use an eye bolt with about a four inch threaded portion to allow room for adjustment. You can see the eye bolt, just visualize the stem going through the A arm, with the rubber parts, shock retaining washer and nylock nut under the A arm
