Small Block Edelbrock heads CNC ported? #445948
08/22/09 12:08 PM
08/22/09 12:08 PM
NC
Badfish67 Offline OP
NC
Does anyone know who CNC ports Edelbrock heads?
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: Small Block Edelbrock heads CNC ported? [Re: Badfish67] #445949
08/22/09 12:10 PM
08/22/09 12:10 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
hughesengines.com around $2500 if I remember for the heads CNC'd
Re: Small Block Edelbrock heads CNC ported? [Re: DaKuda] #445950
08/22/09 12:25 PM
08/22/09 12:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
jeff
at modern cylinder heads...
http://www.moderncylinderhead.com/
Tony
70 AARCuda Vitamin C
Re: Small Block Edelbrock heads CNC ported? [Re: 70AARcuda] #445951
08/22/09 12:32 PM
08/22/09 12:32 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
Jeff @ MCH was great to deal with when he did mine last year.
Re: Small Block Edelbrock heads CNC ported? [Re: 68DART360] #445952
08/22/09 01:15 PM
08/22/09 01:15 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Small Block Edelbrock heads CNC ported? [Re: Stroker Scamp] #445953
08/22/09 01:56 PM
08/22/09 01:56 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Not to high jack but would this be the best bang for the buck if you want 550-600hp?
Re: Small Block Edelbrock heads CNC ported? [Re: sshemi] #445954
08/22/09 05:34 PM
08/22/09 05:34 PM
NC
NC
Anyone have an idea what the cost is to CNC port the Edelbrock heads?
Re: Small Block Edelbrock heads CNC ported? [Re: Badfish67] #445955
08/22/09 05:44 PM
08/22/09 05:44 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
well..if you can wait..
modern cylinder head has winter special ....
I paid 800 dollars which includes cnc the heads, the valve job and reassembly of the heads..this was on a new set of sb eddy heads that i shipped to them.
also included port flow sheet on intake and exhaust port..
Tony
Re: Small Block Edelbrock heads CNC ported? [Re: 70AARcuda] #445956
08/22/09 05:47 PM
08/22/09 05:47 PM
sweden
sshemi Offline
sshemi  Offline
sweden
what did they flow?
Re: Small Block Edelbrock heads CNC ported? [Re: sshemi] #445957
08/22/09 06:48 PM
08/22/09 06:48 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
view pdf attachment
close chamber heads
5434020-img006.pdf (375 downloads)
Tony
Re: Small Block Edelbrock heads CNC ported? [Re: 70AARcuda] #445958
08/23/09 01:28 AM
08/23/09 01:28 AM
NC
NC
Hey AAR...
The CNC port job you got from MCH, is that the most that the Edelbrock heads can be ported? And yes I can wait till the winter.
Re: Small Block Edelbrock heads CNC ported? [Re: Badfish67] #445959
08/23/09 08:00 AM
08/23/09 08:00 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Hey AAR...
CNC anything is never the "most" you can get out of a casting. The CNC program has to be conservative because it has to protect for casting shift...
Re: Small Block Edelbrock heads CNC ported? [Re: Badfish67] #445960
08/23/09 03:57 PM
08/23/09 03:57 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
also. if you use a 2.05 valve the intake will flow over 300 cfm..
Tony
Re: Small Block Edelbrock heads CNC ported? [Re: 70AARcuda] #445961
08/23/09 04:25 PM
08/23/09 04:25 PM
NC
NC
Thanks Tony...
This winter i'm going to send my heads to MCH for some porting and maybe some 2.05's.
Re: Small Block Edelbrock heads CNC ported? [Re: 70AARcuda] #445962
08/23/09 05:20 PM
08/23/09 05:20 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
RyanJ hand ported mine with 2.05 valves and they peak out at 285 on his flow bench-but are 285 from .500 lift up.. There is a lot of difference in flow benches so flow numbers are only a guideline. If you need a true 300+ cfm you may want to get better heads.
Re: Small Block Edelbrock heads CNC ported? [Re: BobR] #445963
08/23/09 10:14 PM
08/23/09 10:14 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my CNC IndyBrocks flow over 300 on Ryan flow bench with a 2.05 intake valve
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Small Block Edelbrock heads CNC ported? [Re: 70AARcuda] #445964
08/23/09 11:32 PM
08/23/09 11:32 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Are you sure he's going to do it again this winter?
Re: Small Block Edelbrock heads CNC ported? [Re: WILD BILL] #445965
08/24/09 08:31 AM
08/24/09 08:31 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
dont know...will have to wait and see..but for the few minutes i talked to him on the phone...sounds like he gets some good cash flow from the work...
Tony
Re: Small Block Edelbrock heads CNC ported? [Re: 70AARcuda] #445966
09/11/09 07:20 PM
09/11/09 07:20 PM
Manassas, VA USA
Scamp451 Offline
Scamp451  Offline
Manassas, VA USA
If he does run this special or group buy, I think it is usually listed in the hot deals section. If I end up geting a set, this could be an option.
Re: Small Block Edelbrock heads CNC ported? [Re: Scamp451] #445967
09/12/09 01:47 PM
09/12/09 01:47 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
hughes has a special running on CNC heads now
https://board.moparts.org/ubbthreads/show...e=0#Post5471828
2017 Grand Cherokee Overland
