Aftermarket water pump housing - passenger side outlet #445946
08/22/09 11:44 AM
08/22/09 11:44 AM
SeventySatellite Offline OP
Any advantage to these besides having a shorter hose length?
Re: Aftermarket water pump housing - passenger side outlet [Re: SeventySatellite] #445947
08/22/09 12:02 PM
08/22/09 12:02 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
If, for example, you had a small block car that you converted to a big block, and the SB radiator lower port was on the passenger side you could spend the the money on the water pump, or $400.00 on a new radiator with the port on the drivers side.
