Replace my /6 with what motor/tranny for my '64 Belvd #445456
08/21/09 09:21 PM
08/21/09 09:21 PM
N. Syracuse, NY
'64 Belvedere Offline OP
N. Syracuse, NY
I have a '64 Belvedere 4dr and was wondering what was the best motor/tranny combo to put in this. I don't know what tranny is in it now or what rearend. If anyone knows what came stock or how to check to find out. I know I need a new k member and better brakes. ZAnything off the top of your heads would help.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445457
08/21/09 09:26 PM
08/21/09 09:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
/6 all the way.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: Alaskan_TA] #445458
08/21/09 09:58 PM
08/21/09 09:58 PM
N. Syracuse, NY
N. Syracuse, NY
I was thinking something bigger. Had someone say I wouldn't be happy because the car is to big for the motor. I was thinking 318, 383 or 426 and what ever tranny worked best with that motor.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445459
08/21/09 10:00 PM
08/21/09 10:00 PM
440 or 400(451)
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445460
08/21/09 10:01 PM
08/21/09 10:01 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Make it a big block 4 speed sleeper. Put a 440 with a 65 or newer 4 speed transmission and a set of dog dish hubcaps and go out and annihilate the camaros and mustangs. You'll need to swap the /6 k-member to a V-8 k-member, 273, 318, 361, 383, 426 wedge cars all used the same k-member, /6 k-frame is /6 only.
Also cars like your Belvedere and other 1964 B-bodies like Savoy, Fury, Sport fury, and Dodge Polara's came with the 8 3/4 rear axle. Which is a good axle except for the tapered end axles, but you can get a new set of axles from Moser, Strange, Mark Williams, Yukon, etc... any number of companies. Swapping to the later bolt-in axles makes swapping gears and doing any kind of brake repairs a lot easier.
Is your car a pushbutton automatic, 3 on the tree or four on the floor?
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: 440fied] #445461
08/21/09 10:08 PM
08/21/09 10:08 PM
N. Syracuse, NY
N. Syracuse, NY
It is a push button on the dash. I think it is a three speed. What about doing brake conversions on the rear axle?
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445462
08/21/09 10:15 PM
08/21/09 10:15 PM
IN
ahy Offline
ahy  Offline
IN
If you do a small block, I'd suggest 360. The extra cubes and torque would be welcome. Plus if you want to hot rod it, a 360 is a better starting point.
For brakes, the front's do 70% of the stopping. An upgrade to discs up front would get you a lot more benefit than changing the rears. Look at MOPAR Action's web site for brake choices using later year OE parts or Master Power Brakes for pre-packaged kits.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: ahy] #445463
08/21/09 10:22 PM
08/21/09 10:22 PM
N. Syracuse, NY
N. Syracuse, NY
You would leave the rear brakes stock and not change them to disc with bigger engine. I would most diffinately do the fronts.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445464
08/21/09 10:33 PM
08/21/09 10:33 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
If you switch from auto to 4 speed you need to find manual trans pedals, z-bar, downrod, frame side z-bar bracket, bellhousing side z-bar bracket, bellhousing, transmission, shifter rods-levers-mechanism, shifter handle, and a 4 speed floor hump. Cool thing is Brewers performance has all of these parts in stock. Check out their website at http://www.brewersperformance.com/
If you decide to leave the car pushbutton automatic you can either find a big block pushbutton transmission or use a later trans with the Imperial services conversion cables http://www.imperialservices.net/ to operate the transmission or block off the pushbutton on the dash and go to an aftermarket automatic trans shifter on the floor, from B&Mwww.bmracing.com or Hurst. www.hurst-shifters.com/
Definately upgrade the fronts to disc brakes if you decide to do the rears after you swap out the tapered axles out of your car for some later style bolt-in axles you can either go with the original 10" drums or upgrade to 11" drums or convert to disc brakes from a bunch of different companies check out dr.diffs website at http://www.doctordiff.com/ or scarebird classic brakes makes disc brake conversion kits for a bunch of different cars including older mopars http://www.scarebird.com/
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: 440fied] #445465
08/21/09 10:46 PM
08/21/09 10:46 PM
N. Syracuse, NY
N. Syracuse, NY
Was going to use the brake conversion from scarebird. I was wondering if they were any good. It sounded like you just by the brackets from them and get the rest of the stuff you need at NAPA. Does that sound about right. What cars would have had a big block push button tranny in it?
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445466
08/21/09 11:18 PM
08/21/09 11:18 PM
any BB car and you would want a 64 trans to work w your pushbuttons. EDIT 63-65 car
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: RapidRobert] #445467
08/21/09 11:59 PM
08/21/09 11:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
440 or 400(451)
I agree with this. Any bigblock will run good with a small amount of work. I did a 440 as they are not to hard to get and then put the 426 badges on the eng as you could get the 426 Max Wedge or street 426 in them in 64. Ron
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445468
08/22/09 12:05 AM
08/22/09 12:05 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
You are correct, you can use the scarebird brackets and napa parts for their conversion.
You can get a big block 727 pushbutton transmission also called a cable shift transmission from big block powered 63, 64 or 65 B body cars and C-body cars like Chrysler Newport, Newyorker, 300 and Imperials.
The best transmission to find is a 65 cable shift 727 trans. It has a slip yoke on the end instead of the companion flange or ball and trunion joint like the 63 and 64 transmissions do. The slip yoke will handle a lot more abuse than the 63-64 companion flange will. 65 cable shift trannys are getting hard to find and expensive, it might be cheaper to use a later big block 727 trans and the Imperial services cable conversion kit in your car.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: 440fied] #445469
08/22/09 01:23 AM
08/22/09 01:23 AM
N. Syracuse, NY
N. Syracuse, NY
I actually found a guy selling a '65 bb727 tranny with the cable set up from a Imperial for only $200. I guess I better jump on it fast. I guess at this point the question is which bb to go with... a 383, 413, 426 or 440.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445470
08/22/09 01:36 AM
08/22/09 01:36 AM
Real fast & get the TC if you can. 383 is too small, 413 I think needs special pistons??, not sure on 426 wedge availability. 440 or build up a 400 I think a 64 VB will let you run it(the 65 trans) w your 64 pushbuttons but Kunkel will know for sure on that & that way it'll be an easier swap & look/function stock
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: RapidRobert] #445471
08/22/09 10:47 AM
08/22/09 10:47 AM
N. Syracuse, NY
N. Syracuse, NY
So what is the best set up for a 440. Trying to do it on not a ton of money so any good places to pick up cheap parts. Was going to put together motor myself but send it out for any machine work.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445472
08/22/09 11:57 AM
08/22/09 11:57 AM
I see forged cranks for $125, someone posted about 2 good deals for rods, a company that rebuilds them w milodon bolts and secondly scat rods for ~$150 iirc. KB pistons to get quench & your desired CR. Used intakes/carbs are plentiful, Stock electronic ign w recurve & a MP chrome box.
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: '64 Belvedere] #445473
08/22/09 03:15 PM
08/22/09 03:15 PM
Southeast Michigan
Mr Belvedere II Offline
Southeast Michigan
If you on the cheap, you may want to re-consider swapping out the /6. Cheap being relative, I have not found a way to install a RB in my 67 Belvedere for much under $2000 and I already have an engine, trans and K-Member.
That being said, you will find it much easier to swap an A engine to this car without changing the K-member - I am fairly certain Schumacher makes a /6 to A mount for a B body.
In the end: What do you want from the car?
If it were mine I would put a very mild A engine in it and paint it to look like a vintage police cruiser.
67 Belvedere II 225 Slant Six 383 on the stand The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants. - Thomas Jefferson
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: 440fied] #445474
08/22/09 04:27 PM
08/22/09 04:27 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Correct me if I am wrong guys......an Ebody 8 3/4 will bolt in?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Replace my /6 with what motor/tranny for my '64 Belvd [Re: Mr Belvedere II] #445475
08/22/09 04:54 PM
08/22/09 04:54 PM
N. Syracuse, NY
N. Syracuse, NY
I did call Schumacher and they said I had to change the k member for a slant 6 b body motor change. I think $2000 isn'tbad to swap... I was thinking almost double, not worried then.
