Champion N9Ys? #445414
08/21/09 08:57 PM
08/21/09 08:57 PM
CONNECTICUT
RoyceFlo73 Offline OP
CONNECTICUT
I am changing out the spark plugs on a 1967 273 Sb. It's in my 73 dart and i am running a Weisco HEI ignition in it. I was reading through some books of mine and the champion N9Ys were listed as a good spark plug for the street.
But i presume the 9 is the heat rating, and that seems a little cool for a street engine with the lower compression my engine has ( i believe the 67 2barrel had around 8.8-1?)
Any thoughts?
Re: Champion N9Ys? [Re: RoyceFlo73] #445415
08/21/09 09:00 PM
08/21/09 09:00 PM
way too cold for the street
Re: Champion N9Ys? [Re: RapidRobert] #445416
08/21/09 09:08 PM
08/21/09 09:08 PM
CONNECTICUT
CONNECTICUT
thats what I thought.
Any recommendations?
Re: Champion N9Ys? [Re: RoyceFlo73] #445417
08/21/09 09:18 PM
08/21/09 09:18 PM
My "Glenns" manual is showing Champion n14y for 2bbls and n10y on a 4bbl. EDIT the difference is based mainly on the higher CR on the 4bbl unit(iirc 10.5 adverised). I'm assuming you have a 2bbl eng & built it up a little? 12's or 14's might be a good start and I think there are excellent plug reading pics in the archives.
