Dodge Truck Wiring Problems #445271
08/21/09 05:16 PM
08/21/09 05:16 PM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
When I had a factory radio in this vehicle, with the radio on, my interior dome lights would come on and stay on until the radio was turned off. When I would ajust the volume up/down, the dome lights fluctuates dim/bright. three factory radios and now a after market radio later, problem persists. Can anyone help me?
Re: Dodge Truck Wiring Problems [Re: Moparmedic440] #445272
08/21/09 06:13 PM
08/21/09 06:13 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It would help to know the year and model of the truck.
Re: Dodge Truck Wiring Problems [Re: stumpy] #445273
08/21/09 06:20 PM
08/21/09 06:20 PM
Easton, Kansas
Easton, Kansas
96 Ram 1500 4X4
Re: Dodge Truck Wiring Problems [Re: Moparmedic440] #445274
08/21/09 08:46 PM
08/21/09 08:46 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I would start by checking the ground from the cab to the engine.
Re: Dodge Truck Wiring Problems [Re: Lefty] #445275
08/21/09 10:04 PM
08/21/09 10:04 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
It sounds like the power switch for the radio is acting like a door jamb switch should, completing the dome light circuit and illuminating the dome lamp.
You need to trace the wires from the radio harness to the fuse box, and past that if necessary. Sounds like the radio power wire is tapped into the dome light circuit somewhere.
