Speedometer Cable Bracket under Floor Location? #445167
08/21/09 02:37 PM
08/21/09 02:37 PM
cataclysm80 Offline OP
70 Challenger 8-26-69 SPD
The drivers floor was patched in the early 90's before I got the car. The patch was never painted and was already rusted with lots of pinholes when I got the car. I've replaced the floor now, but am missing the spotwelded on bracket/tab that goes on the bottom of the floor to hold the speedometer cable.
1. Is there anywhere I can get this tab, or do I need to make one?
2. What are the measurements for the tabs location?
As often as people replace floors, hopefully the answer is readily available. (I could also use measurements for where to locate the dimmer switch.)
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445168
08/21/09 02:38 PM
08/21/09 02:38 PM
Found this picture. Here's what the bracket looks like.
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445169
08/21/09 02:42 PM
08/21/09 02:42 PM
You can see it in this picture too. (ignore the red marks around the torque boxes)
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445170
08/23/09 06:47 PM
08/23/09 06:47 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hi.i now there is is a bracket on ebag somewhere.i think it was 9.99$ buy it now.but i guess if ju just could get the messurements you could make one as well.anyway if you want to i think i can locate that ad on ebag,i think i bought my hornring from that seller. overandout Anders
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445171
08/24/09 10:04 AM
08/24/09 10:04 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hej,dont know if its the right one,maybe.ebag seller is nb1920. cuda challenger 70 71 NOS framerail speedo cable clip.i dont think it looks the same but maybe just is bent a little different.
Re: Speedometer Cable Bracket under Floor Location? [Re: cuda-sweden] #445172
08/24/09 02:15 PM
08/24/09 02:15 PM
Many thanks for the help.
Here's a link to it that will make it easier for everyone to see.
http://cgi.ebay.com/ebaymotors/Cuda-Chal...sQ5fAccessories
I agree, it doesn't look quite right. I don't know of anywhere such a clip would attach to the frame. The only one I know of is welded to the bottom of the floor and pictured above. (I ran without one on another car several years back and melted my speedo cable on the headers.) Maybe that clip in the auction is for a different car?
I still appreciate the help though!
Someone should tell AMD they need to include these on their floor pans.
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445173
08/24/09 03:03 PM
08/24/09 03:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW I've cut a few of those clips off junk yard cars, when stripped they are copper clad probably to prevent corrosion... As far as location I'd say your pictures pin that down pretty well...
BTW Nice job of trying to track down allot of details that are typically ignored...
The knowledge is out there it's a matter getting it all rounded up & saved...
Re: Speedometer Cable Bracket under Floor Location? [Re: 1_WILD_RT] #445174
08/24/09 03:50 PM
08/24/09 03:50 PM
Thanks. I'm saving all the info so I can pass it on to the next guy that needs help.
Is this an E body only thing, or did all the 70 mopars have this? Maybe I could find one at a junkyard.
Copper clad huh? I bet that makes it tough to weld onto the car. Maybe I should just fabricate one.
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445175
08/24/09 07:29 PM
08/24/09 07:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
71-74 b-body for sure, I think the later stuff has it to... When you hit it with the wire feed the copper just burns off no problem...
Re: Speedometer Cable Bracket under Floor Location? [Re: 1_WILD_RT] #445176
08/24/09 09:27 PM
08/24/09 09:27 PM
New Jersey
myrddin Offline
myrddin  Offline
New Jersey
That clip in the ebay link, is the one on the front frame rail. The first clip the cable passes through after it comes out of the firewall.
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445177
08/24/09 10:17 PM
08/24/09 10:17 PM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
Tav
My 73 dart sport has the same clip welded to the underside of floor
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Speedometer Cable Bracket under Floor Location? [Re: myrddin] #445178
08/25/09 07:25 AM
08/25/09 07:25 AM
Thanks, neither of my cars have one, so I hadn't noticed. Does it attach with a screw or bolt or something? Anyone have a picture?
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445179
08/25/09 08:49 AM
08/25/09 08:49 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This clip just snaps over the edge of the frame rail right at the base of the firewall . approx 6 to 8" rearward of the prop valve.
Re: Speedometer Cable Bracket under Floor Location? [Re: gtx6970] #445180
08/25/09 08:28 PM
08/25/09 08:28 PM
Hi Bill
Do you happen to sell those? What's the item #? I'll add it to my shopping list. I'm about done figuring what I need and should place an order soon.
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445181
08/25/09 08:32 PM
08/25/09 08:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tav,
Yes I stock them.$5 pt # SC
here's an installed pic on a B-body just for reference. lower left of the picture
Re: Speedometer Cable Bracket under Floor Location? [Re: gtx6970] #445182
08/25/09 08:53 PM
08/25/09 08:53 PM
Thanks, you should be hearing from me soon
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445183
09/03/09 09:33 PM
09/03/09 09:33 PM
Well, in case anyone else is looking for the info, here's what I managed to gather. The measurements were taken off a 70 'cuda. I'm not sure how much placement varied from the factory.
This pic is not that car, it is another 70 car that has had its floors replaced with later style aftermarket floor pans, but the pic works well for displaying the measurements.
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445184
09/03/09 09:37 PM
09/03/09 09:37 PM
Oh, by the way, I also found that the dimmer switch is located 2 3/4 out from where the floor pan meets the kick panel. I don't have a measurement down from the seam where the floor meets the firewall yet, but I'm pretty sure the holes are located vertically so that the wiring approaches the switch from the left.
Tav
Re: Speedometer Cable Bracket under Floor Location? [Re: cataclysm80] #445185
09/04/09 10:28 PM
09/04/09 10:28 PM
State of Flux
Dodge Don Offline
Dodge Don  Offline
State of Flux
I know 70 Chargers had them. You either cut one off an old floor pan or have a new one fabricated.
