Holley Strip Dominator or M1 Single plane on my 390cid #445157
08/21/09 02:33 PM
08/21/09 02:33 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Looking for input on which intake would be best and make the most power or are they pretty equal? I'm currently running an Edelbrock RPM Air-gap because it was build as a street/strip motor but we are going to take it off the street and just race it next year.
318 with K-1 4" crank, making 390cid, eagle H-beams, ross flat tops, with 11 to 1, will probably bump up the compression by shaving the Edelbrock heads.
Thanks in advance for your input.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Holley Strip Dominator or M1 Single plane on my 390cid [Re: WadeMetzinger] #445158
08/21/09 02:36 PM
08/21/09 02:36 PM
Out West
408strokerdart Offline
Out West
Strip Dominator is hard to beat for standard port heads.
Re: Holley Strip Dominator or M1 Single plane on my 390cid [Re: WadeMetzinger] #445159
08/21/09 02:37 PM
08/21/09 02:37 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
There's probably very little difference between those intakes.
A Victor 340 would be my first choice.
Re: Holley Strip Dominator or M1 Single plane on my 390cid [Re: S/ST 3040] #445160
08/21/09 03:13 PM
08/21/09 03:13 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Likely mine also, with a weiand excellerator a super close second
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Holley Strip Dominator or M1 Single plane on my 390cid [Re: B3422W5] #445161
08/21/09 03:23 PM
08/21/09 03:23 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
There would be some difference if the strip dominator was highly modified like the one I have in my garage that has about 40 hours worth of port work done to it that I would be willing to sell you
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Holley Strip Dominator or M1 Single plane on my 390cid [Re: WadeMetzinger] #445162
08/21/09 03:34 PM
08/21/09 03:34 PM
AndyF Offline
AndyF  Offline
I haven't done any dyno work on the SB combinations but the Victor 340 sure looks like a better intake than others I've seen. The M1 intake has the new style thermostat housing which can cause problems in some installations.
Re: Holley Strip Dominator or M1 Single plane on my 390cid [Re: B3422W5] #445163
08/21/09 04:35 PM
08/21/09 04:35 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Wade I'm with Don on this. The Weiand 7545 was .15 faster than a Strip or Street Dom. on my old 340. It gets my vote.
Re: Holley Strip Dominator or M1 Single plane on my 390cid [Re: AndyF] #445164
08/21/09 04:59 PM
08/21/09 04:59 PM
Tulsa, Ok
Tulsa, Ok
thanks for the responses guys!
