Holley Strip Dominator or M1 Single plane on my 390cid
#445157
08/21/09 02:33 PM
08/21/09 02:33 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Looking for input on which intake would be best and make the most power or are they pretty equal? I'm currently running an Edelbrock RPM Air-gap because it was build as a street/strip motor but we are going to take it off the street and just race it next year.
318 with K-1 4" crank, making 390cid, eagle H-beams, ross flat tops, with 11 to 1, will probably bump up the compression by shaving the Edelbrock heads.
Thanks in advance for your input.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
