holley carb tuning question
#445097
08/21/09 12:49 PM
08/21/09 12:49 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
Im in the process of tuning my holley 600 to my 318. it seems to be leaning out during mid range acceleration and also a little lean off idle. anyone know what could be the problem? im not an expert on holleys. thanks -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: holley carb tuning question
[Re: fox]
#445103
08/22/09 10:37 AM
08/22/09 10:37 AM
mopars_1
Ridgeland Wi
I know the float level is set right, but Ill have to check in on those other possibilities later. thanks! -kevin
btw, I pulled a spark plug after a little drive and it came out fairly white. Ill change the jets and see what happens.
