holley carb tuning question #445097
08/21/09 12:49 PM
08/21/09 12:49 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Im in the process of tuning my holley 600 to my 318. it seems to be leaning out during mid range acceleration and also a little lean off idle. anyone know what could be the problem? im not an expert on holleys. thanks
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: holley carb tuning question [Re: mopars_1] #445098
08/21/09 01:21 PM
08/21/09 01:21 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Mid range exceleration and lean off idle both point towards the accel pump adjustment. Double check your accel pump with the engine running to see if you have a squirt of fuel as soon as you hit the carb linkage. If your pump is setup correctly, then try a larger squirter.
Note: check your float levels too.
If the issue still exists, then raise the size of your primary jets.
Re: holley carb tuning question [Re: mopars_1] #445099
08/21/09 02:32 PM
08/21/09 02:32 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
You can become an expert (sort of.):
Holley.comTech Service Information
Lots of great Free advice and videos, troubleshooting information, setup info, etc,
Also these FAQ's:
Holley FAQ's
Re: holley carb tuning question [Re: mopars_1] #445100
08/22/09 02:16 AM
08/22/09 02:16 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Which Holley carb? I think the street avenger carbs are tuned a bit lean. Usually the idle and power valve restrictions are smaller than the performance carbs.
Re: holley carb tuning question [Re: 451Mopar] #445101
08/22/09 07:45 AM
08/22/09 07:45 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Increase the front jets one or two sizes.
Set the float too, if it is low dothat first before the jets.
Re: holley carb tuning question [Re: fox] #445102
08/22/09 10:22 AM
08/22/09 10:22 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
make sure your power valve matches the requirements of your engine based on vacuum at those moments you describe when it seems to be lean.
Re: holley carb tuning question [Re: fox] #445103
08/22/09 10:37 AM
08/22/09 10:37 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I know the float level is set right, but Ill have to check in on those other possibilities later. thanks!
-kevin
btw, I pulled a spark plug after a little drive and it came out fairly white. Ill change the jets and see what happens.
1937 Plymouth PT50
Re: holley carb tuning question [Re: 451Mopar] #445104
08/22/09 10:39 AM
08/22/09 10:39 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
im not 100% sure on modle# but it's just an older holley 600.
1937 Plymouth PT50
