E-85 carb conversion what is needed??? #445015
08/21/09 10:54 AM
08/21/09 10:54 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I'm sending my 850 E85 carb back for a bigger one. They don't have 1050 cfms in E85, so I will have to settle for a gas 1050. What all has to be changed on them to make them E-85 compatible?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: E-85 carb conversion what is needed??? [Re: DemonDust] #445016
08/21/09 10:56 AM
08/21/09 10:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Talk to Quick Fuels... they did my 1050 dom
Re: E-85 carb conversion what is needed??? [Re: MR_P_BODY] #445017
08/21/09 11:10 AM
08/21/09 11:10 AM
Menomonee Falls
Menomonee Falls
Ok, I'll check them out.
I'm looking at a proform carb right now. What do you think of those?
SDG Motorsports
Re: E-85 carb conversion what is needed??? [Re: DemonDust] #445018
08/21/09 11:52 AM
08/21/09 11:52 AM
in a chair
mopartony Offline
mopartony  Offline
in a chair
If you do not have the 1050 then talk Patrick at Pro-systems, IIRC he has carbs for E-85.
If that does not pan out go to Heath at raceone85.com he will hook you up.
Re: E-85 carb conversion what is needed??? [Re: mopartony] #445019
08/21/09 02:35 PM
08/21/09 02:35 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I would also go to the E85 Forum and check out Mark Sullens aka DragChevette. I know he assisted 440Jim when he converted his 950HP and he also built a 950HP for member VON. JMO
Re: E-85 carb conversion what is needed??? [Re: rt66jim] #445020
08/21/09 05:57 PM
08/21/09 05:57 PM
S.L . MI
clutch Offline
clutch  Offline
S.L . MI
Quick Fuel has a very complete kit for E 85 conversions.
Re: E-85 carb conversion what is needed??? [Re: clutch] #445021
08/21/09 06:07 PM
08/21/09 06:07 PM
Menomonee Falls
Menomonee Falls
I actually got quite a few PM's VS the replies on this post. I went with a Quick Fuel 1050.
I will be getting their E-85 conversion kit as well, as I will be running E-85 in the summer months and 110 in the winter at the ice drags. I don't think the e-85 will be very good for -10 degrees
SDG Motorsports
