MCH ported RPM flow numbers
#444887
08/21/09 08:05 AM
08/21/09 08:05 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Does anyone have these, i need the info to order a new converter thanks. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: MCH ported RPM flow numbers
[Re: moparniac]
#444890
08/21/09 09:56 AM
08/21/09 09:56 AM
deaks
robin hood country
Thanks but someone posted a sheet with the numbers before and i forgot to print them off but i will do this time. Mick
[Re: deaks]
#444891
08/21/09 10:15 AM
08/21/09 10:15 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
It was in the attachment S/ST 3040 posted. But here it is again.
[Re: S/ST 3040]
#444893
08/21/09 11:00 AM
08/21/09 11:00 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Images that are Bitmps will not show up in the thread. You have to click the attachmnet.
His showed up becuase it is a jpg file.
[Re: S/ST 3040]
#444895
08/21/09 11:17 AM
08/21/09 11:17 AM
WILD BILL
BROOK PARK, OH
What the hell is a Bitmps?
It's the type of file you save it as. The smilie you just posted was a gif
[Re: WILD BILL]
#444896
08/21/09 04:38 PM
08/21/09 04:38 PM
deaks
robin hood country
Sorry the penny didn't drop, got them now though. Why are there no numbers at .550 and .650. Thanks Mick
[Re: deaks]
#444897
08/21/09 05:09 PM
08/21/09 05:09 PM
BradH
Probably because the flow bench operator turned the valve opening tool .100", instead of .050", after measuring the .500" and .600" flow #s...
[Re: BradH]
#444898
08/21/09 06:06 PM
08/21/09 06:06 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Or the Numbers dropped significantly at those two points therefore you just dont disclose them.
[Re: Sport440]
#444899
08/21/09 06:46 PM
08/21/09 06:46 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
No turbulence at .550". Minor turbulence at .650" and port stall at .700" I had mine flowed by the local Hemi-God on his bench, and that's what he found. Jeff's numbers are within 2 cfm at all listed points.
[Re: Sport440]
#444900
08/21/09 06:49 PM
08/21/09 06:49 PM
With Jeff doing the work,I highly doubt it.
#444901
08/21/09 06:57 PM
08/21/09 06:57 PM
Sport440
Canton, Ohio
I know I was just having some fun with Deaks. Its very common to stop getting reads of the airflow every .050 after .500 lift and for some even sooner . mike
[Re: deaks]
#444902
08/21/09 09:12 PM
08/21/09 09:12 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
not all flow benches flow the same that being said I had Jeff do a set of Eddy RPM for me, I had them flowed on a Super Flow 600 bench by my local machine before and after. Jeffs flow sheet showed more CFM (9CFM at .600)than my machine shops did but his work did increase the flow numbers from 280 CFM at .600 to 310 CFM at .600 on the same bench
[Re: mopowers]
#444905
08/22/09 09:14 AM
08/22/09 09:14 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
It looks like my exhaust numbers are a lot less than the other sheets. Any idea why?
I can give a possible reason.......
The cabinet may have a leak, causing high intake readings and low exhaust readings.
