408 stroker info?
#444760
08/20/09 11:36 PM
08/20/09 11:36 PM
Posts: 4,518 Indiana
MonGoo$e
Indiana
I'm in a perfect place right now for a Project guy i guess..73 Duster in bodywork mode but I have to think forward to a Motor, since my 318 is just..a mess..pushrods all bent..valves stuck..might as well 360 this one. Considered a 408 stroker kit.
I typically take my engines in bare block, crank, rod/pistons and Head castings. time i get it back with a bore and balance/build the short block and do the heads, Its like $1200.
I understand a Stroker kit with the parts I need runs about that, and I'm a little in the dark what the block needs done. Info on that would be cool.
Also whats the low down on heads? Honestly, It'd be a street car that "has some really nice power" but mostly a weekend cruiser with some here and there weekday driving.
I'd likely throw an LD340 on it and either a Reworked TQ or a 650 Eddy..I've only had TQ's for Four Barrels, always liked them.
Info on issues, prices, and experiences are appreciated.
Re: 408 stroker info?
[Re: MonGoo$e]
#444763
08/21/09 12:27 AM
08/21/09 12:27 AM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
Small notch needs to be taken out of the Block for the Rod Bolts other then that it's really nothing more then a .30 over bore. Crank and Pistons is really all that changes. Stock rods are fine. You can find kits everywhere just do a search on "Mopar Stroker" and you will find them.
5.9 vs 360 5.9 has Roller Cam if you want to do a Roller, I only know of 4 Shelf Roller Cams from MOPAR right now. If they don't meet your need then you can have your "Core" reground. You will need to replace the stock push rods if you do that since they will be short.
If you decide on 5.9 you have to make a few more decisions. 5.9's did not come with Mech Fuel pumps so the "Stock Roller Cam" does not have an eccentric to drive it. Also the 5.9 Timing Chain cover does not have provisions for one. This really isn't an issue since you can either get an adapter or 2 of the MOPAR Roller Cams have eccentrics. For the Timing Chain Cover the 360's will work.
Oil Pan on the 360's and 5.9's will exchange but finding one for a Car "Center Pump" in a junk yard is rare, 98% of these engines were in trucks and vans.
5.9 stock head's while not the best in the world do flow better then 360's only due to the newer design, but they have a tendency to crack between the valves. 5,9's use pedistal Rockers vice the Shaft Rockers. Just something else you need to consider There are alot of options for Replacement heads if you need them.
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
