1964 netural safety switch question #444628
08/20/09 10:08 PM
08/20/09 10:08 PM
BigFish69 Offline OP
A one wire netural safety switch from 1964 ply can it be used in later model 727 with a grinder brake valve body and operate the same way. Does the one wire safety switch ground to operate ??
Thanks Tom
Re: 1964 netural safety switch question [Re: BigFish69] #444629
08/20/09 10:13 PM
08/20/09 10:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
Thanks Tom
It depends on which year your going to, some of the pre 1971( I think) will work and later ones won't due to the rooster comb park and nuetral tab length differences in early and later models. I have used the later ones trans. in the early bodys by using the center pin to activate the starter relay
Re: 1964 netural safety switch question [Re: Cab_Burge] #444630
08/20/09 10:27 PM
08/20/09 10:27 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Yes the 64 model grounds to allow a start, so do the later ones on the center post, I've seen both used on the old cars, but the newer style ones are easier to find.
